Connect a DVI display for an extended desktop multi-monitor USB solution. The USB2DVIPRO2 USB to DVI Adapter functions as an external graphics card for Windows and Mac computers - the perfect solution for turning your desktop or laptop computer into a dual or multi-monitor environment, all through the simplicity and convenience of USB.
The USB-DVI Adapter delivers high quality video (up to 1920x1200) for a variety of applications and is capable of simultaneously running up to five additional displays from a single computer (using four USB2DVIPRO2 External Video Adapters). The adapter connects to a host computer through a USB 2.0 port, acting as an external DVI video card to either extend or mirror the desktop shown on the existing display - without having to open the computer case.
Featuring driver support for Microsoft Windows (including Aero themes) and Mac OS X, and with video support for resolutions up to 1920x1200, this USB-DVI video adapter is the ideal solution for a wide range of operating environments as well as large-screen displays/monitors.
                High resolution supportThe adapter supports a maximum output resolution of 1920 x 1200, ensuring crisp and detailed visuals for a variety of applications.
                Dual monitor capabilityBy connecting two displays, this adapter allows for increased screen real estate, facilitating improved productivity in tasks that require multiple windows.
                Broad system compatibilityIt is designed to work seamlessly with both Mac and Windows operating systems, making it an ideal choice for diverse user environments.
                User-friendly featuresThe LED status indicator provides at-a-glance information about the adapter's connection status, enhancing user experience during setup and operation.
                Memory enhanced performanceIncludes 16 MB of built-in memory, which helps to optimize performance when handling high-resolution graphics and video.
- StarTech.com USB to DVI Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB2DVIPRO2) - USB / DVI adapter - USB to DVI-I - 27 m
- USB / DVI adapter
- 1920 x 1200 (WUXGA) support, LED status indicator, 16 MB memory
- Length
- 27 m
- Connector
- 4 pin USB Type A - male (input)
- Connector (Second End)
- 24+5 pin combined DVI - female (output)
- USB / USB 2.0
- Black
- 2-year warranty
- Designed For
- P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
- USB / DVI adapter
- Length
- 27 m
- Black
- 5.5 cm
- 2 cm
- 70 g
- Connector
- Included Accessories
- DVI to VGA adapter
- USB / USB 2.0, FCC, RoHS
- Shipping Width
- 21.1 cm
- Shipping Depth
- 14.6 cm
- Shipping Height
- 4.2 cm
- Shipping Weight
- 245 g
- 2-year warranty
- Designed For
|  | StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.91 |
|  | StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152 | In Stock | £64.55 |
|  | StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter | In Stock | £42.49 |
|  | StarTech.com USB to DVI Adapter - External USB Video Graphics Card for PC and MAC- 1920x1200 | In Stock | £63.44 |
