StarTech.com USB to Dual DP Docking Station
Quicklinx: D5Z7WS00 Mfr#: USBA2DPGB
Create a dual-monitor workstation using your laptop, adding two 4K Ultra HD displays and Gigabit Ethernet. This USB to dual DisplayPort mini docking station makes it easy to create a high-performance dual-4K workstation, connecting your MacBook or Windows laptop to two DisplayPort monitors plus Gigabit Ethernet wired network. The dock features a compact design that's perfect for business professionals who need a highly functional workstation when working or traveling between multiple office locations, or when using shared workspaces.
The mini docking station lets you transform your laptop into a highly productive workstation, by expanding the display capabilities of your laptop across two Ultra HD 4K monitors, even if your laptop video card doesn't natively support it. The USB 3.0 docking station supports low-latency, high-resolution 4K graphics on both video ports, using DisplayPort monitors. It works with any laptop that has an available USB 3.0 (USB-A) port.
The mini dock supports DisplayLink graphics technology, with the DisplayLink-6950 chipset, to provide support for dual 4Kp60 displays. With the dual-4K mini dock, you can connect: 2x 4K DisplayPort displays at 4096 x 2160 resolution @ 60Hz / 3840 x 2160 @ 60Hz; Single 5K display at 5120 × 2880 @ 60Hz.
The mini docking station is ideal for producers, graphic and web designers, engineers, architects and many other professionals who work on advanced graphics applications. It offers a fast and easy way to maximize your laptop's workable screen space, giving you three screens in total when coupled with your laptop's display.
The mini dock's compact size is ideal for business professionals working in space restricted workspaces or multiple locations, and require a high-performance dual-monitor workstation.
The Gigabit Ethernet port provides a reliable network connection in areas where Wi-Fi is limited or unavailable.
The mini docking station ensures easy plug-and-play setup with no drivers required. It's bus-powered from your laptop, so no external power adapter is required.
  • Increase Your Productivity with Two 4K Monitors
    The dual DisplayPort adapter adds two DP video outputs to your USB laptop, with resolution support up to 4K. Working on two monitors increases your productivity by giving you more screen space. You can simultaneously access multiple applications and reference material on one display while composing on the other.
  • Access Hardwired Networks with a GbE Port
    Ethernet ports on modern laptops are uncommon, and wireless networks are less secure and less reliable than a hardwired connection. With the GbE port on this portable docking station that features an Ethernet adapter you can access wired LANs even if your USB 3.0 laptop doesn't have an Ethernet port.
  • Maximize Portability with a Miniature Docking Station
    The dock features a compact design that's perfect for business professionals who need portable office desk accessories for traveling between multiple office locations, or shared workspaces. The USBA2DPGB is TAA compliant and backed by a 3-year StarTech.com warranty and free lifetime technical support.
StarTech.com USB 3.0 Mini Dock, Dual Monitor USB-A Docking Station w/ DisplayPort 4K 60Hz Video & Gigabit Ethernet, 1ft (30cm) Cable, Portable USB 3.1 Gen 1 Type-A Laptop Adapter, 4K Dock - DisplayLink Mini Dock (USBA2DPGB) - docking station - USB - 2 x DP - 1GbE
Docking station
Docking Interface
USB
Video Interfaces
2 x DP
5.8 cm x 13 cm x 2 cm
126 g
Gigabit Ethernet
3-year warranty
Docking station
5.8 cm
13 cm
2 cm
126 g
Enclosure Colour
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 1.1, USB 2.0, USB 3.0
2 x display / video - DisplayPort - 20 pin DisplayPort , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x SuperSpeed USB cable - integrated - 14 cm
Wake on LAN, USB powered, full duplex support, 4K Ultra HD, DisplayLink DL-6950 chipset
FCC, RoHS, WEEE, DisplayLink Plug and Display, RCM
Microsoft Windows XP 32-bit, Ubuntu 14.04, Ubuntu 16.04, Apple MacOS X 10.6 - 10.12, Google Chrome OS 55 or later, Linux Kernel 4.2 or later, Ubuntu 19.04, Apple macOS 11.0, Apple macOS 10.14 - 10.15, Microsoft Windows Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Limited warranty - 3 years
D5Z7 StarTech.com 1m Black SuperSpeed USB 3.0 Extension Cable A to A - M/F In Stock £6.71
D5Z7 StarTech.com Universal USB 3.0 Laptop Docking Station - Dual Video HDMI DVI VGA with Audio In Stock £56.02
D5Z7 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - Black In Stock £29.53
D5Z7 StarTech.com USB 3.0 to Gigabit Ethernet Adapter NIC w/ USB Port - White In Stock £27.51
D5Z7 StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0 In Stock £57.25
D5Z7 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £9.01
