StarTech.com USB Stereo Audio Adapter External Sound Card
Quicklinx: 5D3LWS00 Mfr#: ICUSBAUDIOB
Interface: USB 2.0
Sound Output Mode: Stereo
19 In Stock
£14.50 ex VAT
£17.40 inc VAT
Add headphone and MIC audio connectors through USB.
This USB Audio adapter converts a USB port to an audio port, allowing you to add headsets and microphones to your computer without the need to unplug other devices!
Compliant with USB 2.0 and USB audio device specification 1.0, the USB audio adapter couldn't be any simpler to install...it's as easy as connecting the adapter to an available USB 2.0 port, then connecting your audio devices to the provided 3.5 mm audio ports as needed.
Compatible with Windows 98SE and up, as well as Mac OS 9.x and later, the adapter integrates into any computer environment, providing superb sound quality and convenience that can't be matched.
StarTech.com USB Sound Card - 3.5mm Audio Adapter - External Sound Card - Black - External Sound Card (ICUSBAUDIOB) - sound card
Sound card
Enclosure Type
External
Interface Type
USB 2.0
4 cm x 8 cm x 1.5 cm
54 g
Sound Output Mode
Stereo
Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Linux LTS versions only, Linux 3.5 or later, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Apple macOS 13.0
P/N: MU15MMS, MU6MMS, TB33A1C
Sound card
External
Interface Type
USB 2.0
4 cm
8 cm
1.5 cm
54 g
Enclosure Colour
Audio Output
Sound Output Mode
Stereo
1 x microphone - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm
FCC, RoHS
Software
Drivers & Utilities
Limited warranty - 2 years , Technical support - lifetime
5D3L StarTech.com USB to Stereo Audio Adapter Converter In Stock £14.15
5D3L StarTech.com USB Stereo Audio Adapter External Sound Card In Stock £14.50
5D3L StarTech.com 7.1 USB Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £29.60
5D3L StarTech.com USB Stereo Audio Adapter External Sound Card with SPDIF Digital Audio In Stock £24.30
Resources
The following resources are available for the StarTech.com USB Stereo Audio Adapter External Sound Card
Interface: USB 2.0
