StarTech.com USB Serial DCE Adapter Cable 2m
Quicklinx: J1JRWS00 Mfr#: 1P6FFCN-USB-SERIAL
Length: 2m
£26.75 ex VAT
£32.10 inc VAT
The 6.6ft/2m USB to Null Modem Serial Adapter Cable from StarTech.com is designed for robust connectivity between devices. This cable features a USB Type-A connector on one end and a 9-pin D-Sub (DB-9) connector on the other, ensuring compatibility with various serial devices. With compliance to USB 2.0 standards, it offers reliable data transfer rates up to 921.6 Kbps, ideal for professional and home applications.
Crafted with EMI/RFI protection and electrostatic discharge (ESD) protection, this cable is built to provide stable connections without interference. The FTDI controller ensures effective communication between connected devices, while the LED status indicator keeps users informed of connection status. The TPE connector housing provides durability for frequent use.
  • Reliable connectivity
    This cable utilizes a USB Type-A connector for easy Plug-and-Play connection, ensuring quick setup and compatibility with a variety of devices.
  • High-speed data transfer
    With a data rate of up to 921.6 Kbps, this adapter cable ensures fast data exchange, making it suitable for data-heavy applications.
  • Durable construction
    The cable features a sturdy TPE connector housing that enhances durability, providing reliability even with regular use.
  • Enhanced protection
    Emi/rfi protection combined with ESD protection safeguards against external interference, ensuring stable and secure data transmission.
  • Effective monitoring
    An LED status indicator is included to provide visual feedback on the connection status, facilitating ease of use and troubleshooting.
StarTech.com 6.6ft/2m USB to Null Modem Serial Adapter Cable, FTDI, RS232 - USB / serial cable - USB to DB-9 - 2 m
USB / serial cable
FTDI controller, EMI/RFI protection, bus powered, electrostatic discharge (ESD) protection, LED status indicator, TPE connector housing, 921.6 Kbps data rate
Length
2 m
Connector
4 pin USB Type A - male
Connector (Second End)
9 pin D-Sub (DB-9) - female
USB / USB 2.0
USB / serial cable
Shielding Material
Copper
Plated Connector
Gold
Length
2 m
70 g
Connector
USB / USB 2.0, RS-232
Shipping Depth
22 cm
Shipping Height
20 cm
Shipping Weight
95 g
J1JR StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.15
J1JR StarTech.com 6 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.30
J1JR StarTech.com 2m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.81
J1JR StarTech.com 3m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £5.16
J1JR StarTech.com 0.5m Black Straight Through DB9 RS232 Serial Cable - M/F In Stock £4.22
Length: 2m
