The 1 ft/30 cm USB to Null Modem Serial Adapter Cable from StarTech.com offers a reliable solution for connecting devices with a serial port. This cable features a robust build, including a shielded design with copper material, ensuring EMI/RFI protection and electrostatic discharge (ESD) protection. The LED status indicator provides clear visibility of the cable's operational status, while the FTDI FT232R chipset enhances compatibility and performance. With a data rate of 921.6 Kbps, this compact adapter cable is bus powered, making it versatile for various applications.
In addition to its durability and performance, the molded and rugged construction of this cable allows for extended use in different environments. The 4-pin USB Type-A male connector easily connects to USB ports, while the 9-pin D-Sub (DB-9) female connector ensures compatibility with various devices. Compliant with RoHS and WEEE standards, this cable is functional and eco-friendly as well. Experience seamless connectivity with the 1 ft/30 cm USB to Null Modem Serial Adapter Cable for all your serial communication needs.
Reliable construction
This adapter cable features a rugged design that ensures durability and reliable performance in various environments, making it suitable for long-term use. -
Effective protection
The cable is equipped with EMI/RFI protection and electrostatic discharge (ESD) protection, safeguarding data transmission and enhancing stability. -
Clear status indication
An LED status indicator provides instant visual feedback on the connection status, making it easier to monitor functionality. -
High-speed data transfer
Capable of supporting data rates up to 921.6 Kbps, this cable enables fast and efficient data exchanges between connected devices. -
Eco-friendly compliance
Designed to meet RoHS and WEEE standards, this cable performs effectively and contributes to environmental sustainability.
- StarTech.com 1ft/30cm USB to Null Modem Serial Adapter Cable, FTDI, RS232 - USB / serial cable - USB to DB-9 - 30 cm
- Technology
- Shielded
- Rugged, molded, Chipset FTDI FT232R, LED status indicator, 921.6 Kbps data rate, bus powered, COM retention, electrostatic discharge (ESD) protection, EMI/RFI protection
- Length
- 30 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female - screwable
- USB 2.0 / USB 1.1
- Black
- 2-year warranty
- Technology
- Shielded
- Shielding Material
- Copper
- Jacket Material
- Thermoplastic elastomer (TPE)
- Plated Connector
- Gold
- Length
- 30 cm
- Black
- 39 g
- Connector
- Included Accessories
- Db9 connector nuts
- USB 2.0 / USB 1.1, RS-232, RoHS, WEEE
- Shipping Width
- 20 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 1.6 cm
- Shipping Weight
- 66 g
- 2-year warranty
