StarTech.com USB Serial DCE Adapter Cable
Quicklinx: J1LWWS00 Mfr#: 1P1FFCN-USB-SERIAL
Length: 30cm
10 In Stock
£20.69 ex VAT
£24.82 inc VAT
The 1 ft/30 cm USB to Null Modem Serial Adapter Cable from StarTech.com offers a reliable solution for connecting devices with a serial port. This cable features a robust build, including a shielded design with copper material, ensuring EMI/RFI protection and electrostatic discharge (ESD) protection. The LED status indicator provides clear visibility of the cable's operational status, while the FTDI FT232R chipset enhances compatibility and performance. With a data rate of 921.6 Kbps, this compact adapter cable is bus powered, making it versatile for various applications.
In addition to its durability and performance, the molded and rugged construction of this cable allows for extended use in different environments. The 4-pin USB Type-A male connector easily connects to USB ports, while the 9-pin D-Sub (DB-9) female connector ensures compatibility with various devices. Compliant with RoHS and WEEE standards, this cable is functional and eco-friendly as well. Experience seamless connectivity with the 1 ft/30 cm USB to Null Modem Serial Adapter Cable for all your serial communication needs.
  • Reliable construction
    This adapter cable features a rugged design that ensures durability and reliable performance in various environments, making it suitable for long-term use.
  • Effective protection
    The cable is equipped with EMI/RFI protection and electrostatic discharge (ESD) protection, safeguarding data transmission and enhancing stability.
  • Clear status indication
    An LED status indicator provides instant visual feedback on the connection status, making it easier to monitor functionality.
  • High-speed data transfer
    Capable of supporting data rates up to 921.6 Kbps, this cable enables fast and efficient data exchanges between connected devices.
  • Eco-friendly compliance
    Designed to meet RoHS and WEEE standards, this cable performs effectively and contributes to environmental sustainability.
StarTech.com 1ft/30cm USB to Null Modem Serial Adapter Cable, FTDI, RS232 - USB / serial cable - USB to DB-9 - 30 cm
USB / serial cable
Shielded
Rugged, molded, Chipset FTDI FT232R, LED status indicator, 921.6 Kbps data rate, bus powered, COM retention, electrostatic discharge (ESD) protection, EMI/RFI protection
Length
30 cm
Connector
4 pin USB Type A - male
Connector (Second End)
9 pin D-Sub (DB-9) - female - screwable
USB 2.0 / USB 1.1
USB / serial cable
Shielded
Shielding Material
Copper
Jacket Material
Thermoplastic elastomer (TPE)
Plated Connector
Gold
Length
30 cm
39 g
Connector
Db9 connector nuts
USB 2.0 / USB 1.1, RS-232, RoHS, WEEE
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.6 cm
Shipping Weight
66 g
J1LW StarTech.com 3 ft Black USB 2.0 Extension Cable A to A - M/F In Stock £4.01
Length: 30cm
