Product
StarTech.com USB PS2 KVM Console Extender Cat5 Extender - 500 ft
Quicklinx: 76VGWS00 Mfr#: SV565UTPGB
Operate a PS/2 & VGA KVM or PC up to 500ft away as if it were right in front of you. The SV565UTPGB PS2 KVM Console Extender Cat5 Extender (500 ft) lets you control a server, computer or multiple computers (connected through KVM Switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 500 ft (150 m) away.
Use your existing keyboard, mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
For added convenience, the Console extender is compatible with any brand of PS/2 KVM Switch.
StarTech.com USB PS2 KVM Console Extender Cat5 Extender - KVM extender
KVM extender
External
United Kingdom
Max Transfer Distance
150 m
2 years warranty
KVM extender
External
United Kingdom
Wired
Max Resolution
1024 x 768
150 m
1 x PS/2 mouse , 1 x PS/2 keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
External power adapter
Installed Qty
2
76VG StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £6.66
76VG StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.64
76VG StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £6.28
76VG StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £14.08
