StarTech.com USB Multi-Media Card Reader
Quicklinx: HLZSWS00 Mfr#: FCREADMICRO3V2
More than 50 In Stock
£16.82 ex VAT
£20.18 inc VAT
The USB 3.0 Multi-Media Card Reader allows for simultaneous read and write operations on SD, microSD, and CompactFlash cards using a single USB-C or USB-A port.
  • Multi-Device Connectivity
    It features a 1ft (30cm) attached cable with a USB-C host connector and an integrated USB-A adapter for multi-device connectivity. The USB Card Reader is driver and software-free, and compatible with all operating systems, including Windows, macOS, Linux, ChromeOS, Android, and iPadOS.
  • Write Protection
    The SD card slot supports the mechanical write protect switch, which prevents accidental or unauthorized deletion, modification, or overwriting of data. This feature allows the use of the same card on multiple hosts while ensuring data protection.
  • Applications
    This USB-powered card reader is designed to be compact and lightweight, making it ideal for mobile users and business travelers who need to store, edit, and transfer content for videography, photography, podcasting, and social media applications.
  • Card Compatibility
    This Card Reader is compatible with High-Capacity and Extended-Capacity SD Cards, such as SDHC, microSDHC, SDXC, and microSDXC. It can also work with miniSD cards when used with adapters (not included). Additionally, it supports Secure Digital v3.0 UHS-I.
StarTech.com USB 3.0 Multi-Media Memory Card Reader, SD/microSD/CompactFlash Card Reader, Portable USB 5Gbps Card Adapter, External USB-C Card Reader with Attached USB-A Adapter - Works with Any Operating System (FCREADMICRO3V2) - card reader - USB 3.0/USB-C
Card reader - external
Supported Memory Cards
CompactFlash Card type II, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SD 3.0 UHS-I
Host Interface
USB 3.0/USB-C
Grey
USB bus powered, Write Protect switch
Host Interface
USB 3.0/USB-C
Grey
38.9 cm
2.8 cm
1.5 cm
45 g
Memory Card
(max)
Required Ports
1 x 9 pin USB Type A , 1 x 24 pin USB-C
Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
RoHS
HLZS StarTech.com CFexpress Type B Card Reader In Stock £19.18
HLZS StarTech.com 4-Port USB-A PCIe Card, 5Gbps In Stock £82.51
HLZS StarTech.com SD Express Card Reader In Stock £31.70
Supported Formats: microSDHC
Supported Formats: SDHC Memory Card
Supported Formats: CompactFlash Card type II
Supported Formats: SDXC Memory Card
Supported Formats: microSDXC
Supported Formats: SD 3.0 UHS-I
Interface: USB 3.0/USB-C
