The USB 3.0 Multi-Media Card Reader allows for simultaneous read and write operations on SD, microSD, and CompactFlash cards using a single USB-C or USB-A port.
Multi-Device Connectivity
It features a 1ft (30cm) attached cable with a USB-C host connector and an integrated USB-A adapter for multi-device connectivity. The USB Card Reader is driver and software-free, and compatible with all operating systems, including Windows, macOS, Linux, ChromeOS, Android, and iPadOS. -
Write Protection
The SD card slot supports the mechanical write protect switch, which prevents accidental or unauthorized deletion, modification, or overwriting of data. This feature allows the use of the same card on multiple hosts while ensuring data protection. -
Applications
This USB-powered card reader is designed to be compact and lightweight, making it ideal for mobile users and business travelers who need to store, edit, and transfer content for videography, photography, podcasting, and social media applications. -
Card Compatibility
This Card Reader is compatible with High-Capacity and Extended-Capacity SD Cards, such as SDHC, microSDHC, SDXC, and microSDXC. It can also work with miniSD cards when used with adapters (not included). Additionally, it supports Secure Digital v3.0 UHS-I.
- StarTech.com USB 3.0 Multi-Media Memory Card Reader, SD/microSD/CompactFlash Card Reader, Portable USB 5Gbps Card Adapter, External USB-C Card Reader with Attached USB-A Adapter - Works with Any Operating System (FCREADMICRO3V2) - card reader - USB 3.0/USB-C
- Product Type
- Card reader - external
- Supported Memory Cards
- CompactFlash Card type II, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SD 3.0 UHS-I
- Host Interface
- USB 3.0/USB-C
- Grey
- USB bus powered, Write Protect switch
- 2-year warranty
- Product Type
- Host Interface
- USB 3.0/USB-C
- Grey
- 38.9 cm
- 2.8 cm
- 1.5 cm
- 45 g
Memory Card
- Capacity
- (max)
- Required Ports
- 1 x 9 pin USB Type A , 1 x 24 pin USB-C
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Android, Google Chrome OS, Apple iPadOS
- RoHS
- Limited warranty - 2 years
StarTech.com CFexpress Type B Card Reader | In Stock | £19.01 |
StarTech.com 4-Port USB-A PCIe Card, 5Gbps | In Stock | £78.58 |
StarTech.com SD Express Card Reader | In Stock | £31.89 |
