StarTech.com USB Galvanic Isolator 6KV
Quicklinx: J1LSWS00 Mfr#: U1-USB-ISOLATOR
£50.05 ex VAT
£60.06 inc VAT
The StarTech.com USB Galvanic Isolator 6KV offers protection for your devices against electrical surges and spikes, ensuring reliable performance in challenging environments. Designed to operate in extreme temperatures ranging from -30°C to 75°C, this surge isolator accommodates humidity levels from 0 to 95% without condensation. The device features flame-retardant and wear-resistant materials, contributing to its durability and longevity. Equipped with LED status indicators, it provides real-time monitoring of operational status while complying with standards such as FCC, CE/LVD, and IEC/EN 62368-1.
This surge isolator’s 6000V ESD protection safeguards sensitive electronic equipment from potential damage. The device supports external mounting and includes an easy DIN rail mount option for installation. With Plug-and-Play compatibility, it integrates into existing setups, making it a suitable choice for professionals who require both safety and efficiency.
  • Reliable protection against surges
    The USB Galvanic Isolator features 6000V ESD protection, ensuring that sensitive electronics are shielded from potentially damaging electrical spikes, enhancing the safety and longevity of devices.
  • Broad temperature range
    Designed to function effectively in extreme conditions, this isolator operates between -30°C and 75°C, making it suitable for diverse environments and applications.
  • Easy monitoring
    With integrated LED status indicators, users can easily keep track of the operational status of the device, allowing for prompt attention to any issues.
  • Durable construction
    Constructed from flame-retardant and wear-resistant materials, this surge isolator is designed to withstand the rigors of daily use while maintaining its protective capabilities.
  • Versatile installation
    The external form factor and DIN rail mount feature provide flexibility in installation, making it convenient to integrate into existing setups.
StarTech.com USB Galvanic Isolator 6KV, Electrical Isolated USB 2.0/1.1 - surge isolator - TAA Compliant
Surge isolator - external
TAA Compliant
Max Spike Voltage
6000 V
1 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
LED status indicators, flame retardant, wear-resistant, DIN rail mount, LED indicators, galvanic isolation, 6000V ESD protection, 15kV ESD protection (Air), 8kV ESD protection (Contact)
IP40, FCC, Plug and Play, CE/LVD, IEC/EN 62368-1
TAA Compliant
-30 °C
75 °C
0 - 95% (non-condensing)
J1LS StarTech.com Ethernet Network Isolator, TAA In Stock £33.41
