StarTech.com USB Extender Hub, 10m, USB 3.0
Quicklinx: HFP9WS00 Mfr#: U01043-USB-EXTENDER
Type: USB Extender
Interface: USB 3.2
Speed: 5Gbps
Ports: 4
Form Factor: External
Hurry, only 3 left in stock!
£116.04 ex VAT
£139.24 inc VAT
The 32.8ft USB 3.0 Extension Cable with 4-Port USB Hub and 5Gbps transfer rates enables multiport connectivity at distances that exceed standard USB 3.0 distance and power source limitations. Daisy chain up to two USB active extension cables for a maximum range of 65.6ft (20m).
  • Power Options
    Active electronics allow the USB-A Hub to function without requiring external power, multiplying the installation possibilities and accelerating any deployment. In addition, the 5V4A DC power adapter supports USB peripherals that require additional power. Control multiple USB peripherals in remote locations (e.g., webcams, CCTV remote monitoring, remote printers, SSDs, HDDs, scales, mice, keyboards, and other devices) using this 4-port 32.8ft (10m) USB extension cable.
  • Host and Device Compatibility
    The backward compatibility with USB 2.0 and 1.1 ensures functionality with legacy equipment. The hub/cable features USB 3.0/3.2 Gen 1 with data transfer speeds up to 5 Gbps and plug and play (PnP) setup on any operating system, enabling rapid deployment. The Level-2 ESD protection (4kV air and 4kV contact) and the cable shielding enhance USB device safety and minimize EMI. The USB Extender Hub is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com USB Extender Hub, 10m USB 3.0 Extension Cable with 4-Port USB Hub, Active/Bus Powered USB Repeater Cable, Optional 20W Power Supply Included - USB-A Hub w/ ESD Protection (U01043-USB-EXTENDER) - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Performance
Data transfer rate: 5 Gbps
Plastic housing, 4KV ESD Protector (contact discharge), 4KV ESD Protector (air-gap discharge), wake on USB, bus powered
USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1
AC 100-240 V 0.6 A
4 cm x 10.1 cm x 1.8 cm
100 g
Black, silver
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.2 Gen 1
Performance
X VIA VL817
Status Indicators
1 x USB 3.2 Gen 1 Type A , 4 x USB 3.2 Gen 1 Type A
External power adapter
Power Provided
20 Watt - DC 5 V - 4 A
AC 100-240 V
Electric Current Required
0.6 A
Black, silver
1 x USB active cable - 10 m
Plug and Play, FCC, WEEE, RCM
4 cm
10.1 cm
1.8 cm
100 g
Shipping Width
19 cm
Shipping Depth
22.5 cm
Shipping Height
5.5 cm
Shipping Weight
1 kg
Limited warranty - 2 years , Technical support - assistance - lifetime
50 °C
30 - 70%
Min Storage Temperature
-40 °C
Max Storage Temperature
55 °C
Type: USB Extender
Interface: USB 3.2
Speed: 5Gbps
Ports: 4
