The 32.8ft USB 3.0 Extension Cable with 4-Port USB Hub and 5Gbps transfer rates enables multiport connectivity at distances that exceed standard USB 3.0 distance and power source limitations. Daisy chain up to two USB active extension cables for a maximum range of 65.6ft (20m).
Power Options
Active electronics allow the USB-A Hub to function without requiring external power, multiplying the installation possibilities and accelerating any deployment. In addition, the 5V4A DC power adapter supports USB peripherals that require additional power. Control multiple USB peripherals in remote locations (e.g., webcams, CCTV remote monitoring, remote printers, SSDs, HDDs, scales, mice, keyboards, and other devices) using this 4-port 32.8ft (10m) USB extension cable. -
Host and Device Compatibility
The backward compatibility with USB 2.0 and 1.1 ensures functionality with legacy equipment. The hub/cable features USB 3.0/3.2 Gen 1 with data transfer speeds up to 5 Gbps and plug and play (PnP) setup on any operating system, enabling rapid deployment. The Level-2 ESD protection (4kV air and 4kV contact) and the cable shielding enhance USB device safety and minimize EMI. The USB Extender Hub is backed for two years, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com USB Extender Hub, 10m USB 3.0 Extension Cable with 4-Port USB Hub, Active/Bus Powered USB Repeater Cable, Optional 20W Power Supply Included - USB-A Hub w/ ESD Protection (U01043-USB-EXTENDER) - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 3.2 Gen 1
- Performance
- Data transfer rate: 5 Gbps
- Plastic housing, 4KV ESD Protector (contact discharge), 4KV ESD Protector (air-gap discharge), wake on USB, bus powered
- USB 1.1, USB 2.0, USB 3.0, USB 3.2 Gen 1
- Power
- AC 100-240 V 0.6 A
- 4 cm x 10.1 cm x 1.8 cm
- 100 g
- Black, silver
- 2-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 3.2 Gen 1
- Performance
- Processor
- X VIA VL817
- Status Indicators
- Power
- 1 x USB 3.2 Gen 1 Type A , 4 x USB 3.2 Gen 1 Type A
- Power Device
- External power adapter
- Power Provided
- 20 Watt - DC 5 V - 4 A
- Voltage Required
- AC 100-240 V
- Electric Current Required
- 0.6 A
- Black, silver
- Cables Included
- 1 x USB active cable - 10 m
- Plug and Play, FCC, WEEE, RCM
- 4 cm
- 10.1 cm
- 1.8 cm
- 100 g
- Shipping Width
- 19 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 5.5 cm
- Shipping Weight
- 1 kg
- Limited warranty - 2 years ¦ Technical support - assistance - lifetime
- 0 °C
- 50 °C
- 30 - 70%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 55 °C
