StarTech.com's USB 2.0 Easy Transfer cable offers a convenient solution for migrating files from Windows XP or Windows Vista or Windows 7 computers to the newer Windows 8 platform, using the Windows Easy Transfer software.
Instead of having to transfer files from your old computer to your new one over a network or CD/DVD storage, this high quality data transfer cable lets you connect one Windows computer to another, directly through a USB 2.0 connection, supporting data transfer speeds of up to 480Mbps.
- StarTech.com USB Easy Transfer Cable for Windows 7 Upgrade - direct connect adapter - USB 2.0 - USB 2.0
- Direct connect adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- Ports
- USB 2.0
- Length
- 2.1 m
- Data Link Protocol
- USB, USB 2.0
- USB 2.0
- Black
- System Requirements
- Microsoft Windows Vista / XP / 7
- 2-year warranty
- Designed For
- P/N: PEXUSB7LP
- Form Factor
- External
- USB 2.0
- Ports
- USB 2.0
- Connectivity Technology
- Wired
- USB, USB 2.0
- USB 2.0
- 1 x USB 2.0 - 4 pin USB Type A - male
- FCC
- Black
- Software Included
- Drivers & Utilities
- OS Required
- Length
- 2.1 m
- Limited warranty - 2 years
- Designed For
- StarTech.com 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card
