This USB Wi-Fi adapter adds dual-band wireless connectivity to your laptop, tablet or desktop computer, and features a compact nano-sized form factor. It makes it easy to replace or upgrade your computer's existing wireless capability with access to both 2.4GHz and 5GHz Wi-Fi networks.
The dual-band USB Wi-Fi adapter adds reliable Wireless-AC connectivity to your laptop, tablet or desktop computer. As bandwidth-intensive applications such as online conferencing, HD video streaming, file transfers and gaming become more demanding, the USB Wireless-AC adapter provides greater speed and range for your office or home wireless network. The dual-band Wi-Fi adapter supports maximum data rates of up to 433 Mbps on the less congested 5GHz band, plus up to 150Mbps on the 2.4GHz band.
The USB nano wireless adapter features a compact form factor, so you can plug it into your laptop or tablet with minimal obstruction. The perfect accessory for your laptop, the Wi-Fi adapter is so compact that you can leave it plugged in without worrying about it getting in the way or snagging on something while you're on the go.
The versatile network adapter features a 1T1R (1 transmitter, 1 receiver) antenna design. To integrate with all of your networking devices, the USB 802.11ac adapter is backward compatible with 802.11a/b/g/n networks. The USB Wi-Fi adapter supports USB 2.0 for wide compatibility.
- StarTech.com Wireless USB WiFi Adapter - Dual Band AC600 Wireless Dongle - 2.4GHz / 5GHz - 802.11ac Wi-Fi Laptop Adapter (USB433ACD1X1) - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 2.23 cm x 1.66 cm x 0.85 cm
- 2.4 g
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 600 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Processor
- Ralink RTL8811AU
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Black
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.14
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- DSSS
- 600 Mbps
- Line Coding Format
- DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, BPSK, QPSK, 16 QAM, OFDM
- Frequency Band
- 2.4 GHz, 5 GHz
- Full duplex mode, USB powered, 1T1R MIMO technology
Processor / Memory
- Processor
- Ralink RTL8811AU
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- FCC, RoHS
- Black
- Software Included
- Drivers & Utilities
- OS Required
- 2.23 cm
- 1.66 cm
- 0.85 cm
- 2.4 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90%
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R | In Stock | £12.65 |
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White | In Stock | £13.74 |
StarTech.com USB 2.0 AC600 Mini Dual Band Wireless-AC Network Adapter - 1T1R 802.11ac WiFi Adapter | In Stock | £28.59 |
StarTech.com WiFi 6E USB Adapter/Dongle | In Stock | £66.66 |
