This USB-C Multiport Video Adapter offers a portable solution for connecting USB Type-C devices to HDMI and/or VGA displays, with up to 100W of Power Delivery.
Versatile Video Connectivity
This Multiport Adapter supports a single HDMI display at resolutions up to 4K 60Hz, a single VGA display at resolutions of up to 1920x1200 60Hz or dual-mirrored HDMI and VGA displays at resolutions of up to 1080p. The 3.5mm audio port can be used for connecting speakers while presenting with a VGA projector/display, or headphones. -
Extended Cable Length
The adapter is equipped with an extra-long 12 inch (30cm) attached cable, providing an extended reach, to reduce port and connector strain on 2-in-1 devices, tablets, or laptops on risers/stands. -
Power Delivery
The USB C to HDMI and VGA Adapter is bus powered for easy use while traveling. Optionally, connect a USB-C power adapter and charge your laptop using the Power Delivery 3.0 pass-through feature, supporting up to 100W charging. -
Connectivity for Any Laptop
The USB Type-C Display Adapter is compatible with USB-C DisplayPort Alt-mode, Thunderbolt 3, and Thunderbolt 4 enabled laptops, Ultrabooks, Chromebooks, and MacBooks. Plug and play (driver/software free) compatibility with any operating system such as Windows, macOS, iPadOS, Chrome OS, and Linux. 122-USBC-HDMI-4K-VGA is backed for 3-years by StarTech.com, including free 24/5 multi-lingual technical assistance. Note: This adapter does not support MST or dual extended displays.
- StarTech.com USB C Video Adapter, USB C to HDMI VGA Multiport Adapter w/ 3.5mm Audio Output, 4K 60Hz, HDR, 100W PD 3.0, USB C Monitor Adapter for Laptop, Thunderbolt 3/4 Compatible - USB C Display Travel Adapter (122-USBC-HDMI-4K-VGA) - docking station - USB-C / Thunderbolt 3 / Thunderbolt 4 - VGA, HDMI
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- VGA, HDMI
- 6 cm x 4.5 cm x 1.4 cm
- 41 g
- Grey
- Power
- Power Provided
- 3-year warranty
- Product Type
- Docking station
- 6 cm
- 4.5 cm
- 1.4 cm
- 41 g
- Enclosure Colour
- Grey
Video
- Max Resolution Details
- 3840 x 2160 - 60 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only)
- 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x audio - mini-phone stereo 3.5 mm
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- Active, DisplayPort Alt Mode, HDR support, 100W power delivery (pass-through), wide screen support
- Plug and Play, RoHS, WEEE, HDCP 2.2, USB Power Delivery 3.0
- Limited warranty - 3 years
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 245 g
- 0 °C
- 45 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £16.23 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.98 |
StarTech.com 10ft Ultra High Speed HDMI 2.1 | In Stock | £24.32 |
