Power and charge your laptop, and create a workstation by connecting to a VGA monitor, GbE, and a USB 3.0 device. Expand the connectivity of your USB-C laptop with this USB-C VGA multiport adapter. It connects to your USB-C or Thunderbolt 3 port to add VGA video output, a USB 3.0 (Type-A) port with Fast-Charge capability plus a Gigabit Ethernet network connection. Mac, Windows and Chrome OS compatible, it's the ideal accessory for your MacBook, laptop, tablet, Chromebook, smartphone or other USB-C device (with support for DisplayPort Alt Mode).
This USB-C adapter lets you connect your USB-C laptop or device to an external VGA monitor or projector to give engaging presentations in the boardroom, classroom, or meeting room. It supports HD video resolutions up to 1920 x 1200p @ 60Hz.
Compact and durable, the USB-C multiport adapter is ideal for mobile use, eliminating the need to carry multiple adapters with you. Set up a workstation with a Gigabit Ethernet port and a USB 3.0 port to connect an existing USB device or fast-charge your smartphone or tablet. The adapter features a USB-C port that supports USB Power Delivery 2.0 (60W) so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
The adapter features an attached cable (5.6 in. / 143 mm) to ensure easy setup and supports plug-and-play installation, with no additional software or drivers required.
                Connect to a VGA monitor to give presentationsThis USB-C adapter lets you connect your USB-C laptop or device to an external VGA monitor or projector to give engaging presentations in the boardroom, classroom, or meeting room. It supports HD video resolutions up to 1920 x 1200p @ 60Hz.
                Create a portable workstationCompact and durable, the USB-C multiport adapter is ideal for mobile use, eliminating the need to carry multiple adapters with you. Set up a workstation with a Gigabit Ethernet port and a USB 3.0 port to connect an existing USB device, or fast-charge your smartphone or tablet. The adapter features a USB-C port that supports USB Power Delivery 2.0 (60W) so you can use your laptop's USB-C power adapter to power both your laptop and the multiport adapter.
                Fast and easy setupThe adapter features an attached cable (5.6 in. / 143 mm) to ensure easy setup and supports plug-and-play installation, with no additional software or drivers required. The DKT30CVAGPD is backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com USB C Multiport Adapter, Mini USB-C Dock with Single Monitor VGA 1080p Video, 60W Power Delivery Passthrough, USB 3.1 Gen 1 Type-A 5Gbps, Gigabit Ethernet, Docking Station - Portable USB C Dock (DKT30CVAGPD) - docking station - USB-C - VGA - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- VGA
- 4 cm x 9.6 cm x 1.65 cm
- 46.9 g
- Black
- Networking
- Gigabit Ethernet
- 3-year warranty
- Product Type
- Docking station
- 4 cm
- 9.6 cm
- 1.65 cm
- 46.9 g
- Enclosure Colour
- Black
Video
- Max Resolution Details
- 1920 x 1200 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 1 x network - 1000Base-T - RJ-45 , 1 x SuperSpeed USB 3.0 with Fast Charging - 9 pin USB Type A , 1 x USB-C with Power Delivery - 24 pin USB-C (power only) , 1 x video - VGA - 15 pin HD D-Sub (HD-15)
- Cables Included
- 1 x USB-C cable - integrated - 14.3 m
- USB powered, full duplex support, 60W power delivery
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, UASP (USB Attached SCSI Protocol)
- OS Required
- Google Chrome OS 55 or later, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- Limited warranty - 3 years
- Shipping Weight
- 60 g
- 0 °C
- 45 °C
|  | StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to Micro B Cable - M/M | In Stock | £9.17 |
|  | StarTech.com 0.5m (1.5ft) Black SuperSpeed USB 3.0 Cable A to Micro B - M/M | In Stock | £7.36 |
|  | StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.60 |
|  | StarTech.com USB-C to VGA Adapter with PD | In Stock | £11.93 |
|  | StarTech.com 0.5m USB 2.0 C to A Cable M/M | In Stock | £7.97 |
|  | StarTech.com USB-C to VGA, DVI or HDMI | In Stock | £36.62 |
