StarTech.com USB-C/USB-A Multiport Adapter
Quicklinx: HJFDWS00 Mfr#: 167B-USBC-MULTIPORT
Device Type: USB Hub
Type: [N/A]
Device Screen Size: [N/A]
Colour: [N/A]
27 In Stock
£46.41 ex VAT
£55.69 inc VAT
This USB Type-C & USB Type-A Multiport Adapter turns almost any laptop or desktop into a high-productivity workstation that supports dual external HDMI displays and features a 3-port USB hub. The Mini Dock has a built-in 1.3ft (40cm) USB-C host cable and includes a tethered USB-C to USB-A adapter, so it can support both USB-C and USB-A host computers.
  • Dual Display Adapter
    Enhance productivity with two HDMI output ports for connecting external monitors. The HDMI output ports support resolutions up to 4K 30Hz (Video Output 1, HDMI 1.4), and 1080p 60Hz (Video Output 2, HDMI 1.2). Dual external monitors increase productivity - enabling users to have different applications, documents, or windows open on each monitor.
  • Wide-Range Compatibility
    The Multiport Adapter is compatible with Windows, macOS, and Chrome OS. With its tethered USB-C to USB-A dongle that ensures it ensures seamless USB compatibility with any host running a supported OS. The Multiport Adapter supports dual-extended displays on Apple M1/M2 MacBooks, which are not capable of driving more than one external display natively.
  • Built-in 3-Port USB-A Hub
    The USB-C & USB-A Multiport Adapter features three downstream USB-A ports. For fast and reliable data transfers the built-in USB hub supports SuperSpeed USB 3.2 Gen 1 (5Gbps) and is backward compatible with legacy USB 2.0 and USB 1.1 (HID) devices.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that is compatible with a wide variety of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | USB Event Monitoring Utility : Track and log connected USB devices.
StarTech.com USB-C Multiport Adapter w/Attached USB-C to USB-A Dongle, Dual HDMI (4K30Hz/1080p60Hz), 3x USB-A, Mini Laptop Docking Station, Travel Dock, 1.3ft/40cm Cable - Dual Display M1/M2 MacBook/Windows/Chrome (167B-USBC-MULTIPORT) - docking station - USB-C / USB 3.2 Gen 1 - 2 x HDMI
Docking station
Docking Interface
Video Interfaces
2 x HDMI
5.7 cm x 12 cm x 1.6 cm
114 g
Space grey
3-year warranty
Docking station
5.7 cm
12 cm
1.6 cm
114 g
Enclosure Colour
Space grey
Video
Max Resolution Details
4K - 30 Hz (HDMI1 only) , 1080P - 60 Hz (HDMI2 only)
2 x display / video - HDMI - 19 pin HDMI Type A , 3 x USB 3.2 Gen 1 - 9 pin USB Type A
1 x USB-C cable with USB-C to USB-A dongle - integrated - 40 cm
Dual display support, bus powered, aluminium housing, up to 5Gbps data transfer
WEEE, UASP (USB Attached SCSI Protocol), Thunderbolt 3, Thunderbolt 4
Google Chrome OS, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Microsoft Windows 7 / 8.1 / 10 / 11, Apple macOS Sonoma 14.0
Limited warranty - 3 years
Shipping Width
14.2 cm
Shipping Depth
17 cm
Shipping Height
3 cm
HJFD StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £7.92
HJFD StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.48
HJFD StarTech.com 8in HDMI to DVI-D Video Cable Adapter - HDMI Male to DVI Female In Stock £9.71
HJFD StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
HJFD StarTech.com 6ft Premium Certified HDMI 2.0 In Stock £12.98
HJFD StarTech.com USB-C HDMI Multiport Hub, 140W In Stock £23.07
Type: [N/A]
Colour: [N/A]
