StarTech.com USB-C/USB-A Hub - GbE - RS232
Quicklinx: HQ2WWS00 Mfr#: 5G2A1SGBB-USB-C-HUB
Type: USB Hub
Interface: USB 3.2
Speed: 5Gbps
Ports: 2
Form Factor: External
Hurry, only 2 left in stock!
£62.68 ex VAT
£75.21 inc VAT
Add a unique combination of serial, USB and Ethernet ports to your laptop or PCThis USB Type-C Hub with RS-232 Serial, Gigabit Ethernet, and 100W USB-C Power Delivery Pass-Through adds two USB 3.2 Gen 1 (5Gbps) Type-A ports to a USB enabled computer. The attached 2ft (60cm) USB-C host cable includes a tethered USB-C to USB-A adapter that enables the USB Hub to easily connect to both USB-A and USB-C host computers.RS-232 SerialThe USB Hub adds an RS-232 serial DB/DE-9M (male) connector to a desktop or laptop. The USB to RS-232 adapter features COM retention, which automatically reassigns the COM port value if the cable is disconnected and reconnected, or if the system is rebooted.Gigabit EthernetThe USB hub features a Gigabit Ethernet Network Interface Controller (NIC). The Ethernet adapter is compatible with the IEEE 802.3u/ab standards and supports Wake-on-LAN (WoL), Jumbo Frames, and V-LAN Tagging. The network adapter enhances laptop network reliability, security, and performance, by utilizing wired 10/100/1000Mbps Ethernet.USB Power Delivery Pass-ThroughThis USB hub features 100W USB Power Delivery 3.0 pass-through (85W laptop charging). Connect a power source to the USB-C PD pass-through port to power the connected host device. PD 3.0 features Fast Role Swap (FRS) to prevent USB data disruption when switching power sources (USB-C power adapter to bus power).The USB hub features Overcurrent Protection (OCP) for added protection to the USB hub and any connected devices. OCP prevents faulty USB peripherals from drawing more power than is safely allocated.Plug and PlayThis device is compatible with most major operating systems, including Windows, macOS, and Linux. The Hub is automatically detected, configured, and installed upon connection to a host computer.
  • Versatile connectivity
    Equipped with 2 USB 3.2 Gen 1 Type-A ports, a serial (RS-232) port, and a Gigabit Ethernet port, this hub offers a wide range of connectivity options for various devices and networks, ensuring seamless integration into any setup.
  • Enhanced power delivery
    Supports USB Power Delivery 3.0, allowing for up to 100 W of power to pass through, making it ideal for charging and powering connected devices without the need for an additional power source.
  • Robust performance
    Features such as 256-byte FIFO, Automatic Media-Dependent Interface Crossover (MDIX), and Energy-Efficient Ethernet (EEE) ensure efficient data transfer and reliable connectivity, enhancing the user experience.
  • Advanced networking capabilities
    With support for features like VLAN Tagging, Wake On LAN (WOL), and Fast Role Swap (FRS), this hub is designed to meet the needs of complex networking environments, providing flexibility and control.
  • Durable and compliant
    Built to last, this hub adheres to RCM, RoHS, and WEEE standards, ensuring a high-quality, environmentally friendly product that is designed for durability and compliance.
StarTech.com 2-Port USB-C/USB-A Hub with GbE and RS232 Serial, 2x USB-A - hub - 2 ports
Hub - 2 ports
Subtype
USB
Ports
2 x USB 3.2 Gen 1
Performance
Data transfer rate: up to 5 Gbps , Baud rate: 115.2 Kbps
Jumbo Frame Support
9KB
WOL, VLAN Tagging, USB Power Delivery 3.0, FRS, OCP support, 256-byte FIFO, EEE, flow control, priority encoding, UASP, full duplex mode, Auto MDIX, PXE support, bus powered
IEEE 802.3u, IEEE 802.3ab, IEEE 802.3az, IEEE 802.3x, IEEE 802.1Q, IEEE 802.1p
12.8 cm x 5.5 cm x 1.9 cm
105 g
Space grey
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Linux Kernel 3.0 or later, Microsoft Windows CE .NET 4.2, Microsoft Windows CE .NET 5.0, Microsoft Windows CE .NET 6.0, Apple macOS 10.15 - 10.6, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple macOS Ventura 13.0, Apple macOS Sonoma 14.0, Microsoft Windows XP Embedded, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8/8.1/10/11
Hub - 2 ports
Enclosure Type
Desktop
Subtype
USB
Ports
2 x USB 3.2 Gen 1
Performance
Jumbo Frame Support
9KB
X ASIX / VIA / FTDI VL817-Q7 / VL103-Q4 / AX88179A / FT232RL
Status Indicators
Port status
2 x USB 3.2 Gen 1 Type A , 1 x serial (RS-232) DB-9 COM retention support , 1 x 10/100/1000Base-T RJ-45 , 1 x USB-C (power delivery) 100 Watt
Space grey
1 x USB-C cable with USB-C to USB-A dongle - 60 cm
WEEE, RoHS, RCM
Software Included
Connectivity Tools
12.8 cm
5.5 cm
1.9 cm
105 g
Shipping Width
21.3 cm
Shipping Depth
14.5 cm
Shipping Height
3.4 cm
Shipping Weight
171 g
50 °C
0 - 95% RH
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Type: USB Hub
Interface: USB 3.2
Speed: 5Gbps
Ports: 2
