FLEXIBLE MULTI DISPLAY SETUP: USB 3.1 Gen 2 10Gbps Type-C/A dock supports dual or triple monitor setup (up to 3x 4K 60Hz), using any combination of the 3x DisplayPort 1.4 & 3x HDMI 2.0 w/ HDR ports.
85W POWER DELIVERY: Power & charge USB-C/Thunderbolt 3 workstation laptops/ultrabooks incl Lenovo X1 Carbon, ThinkPad P Series, Dell Latitudes, Precision, XPS 15, HP Spectre, ZBook & MacBook Pro 16.
UNIVERSAL DOCKING STATION: Hybrid dock includes combo 2-in-1 USB-C/USB-A USB-IF Certified host cable; DisplayLink dock supports up to 3 extended displays on Macbook Pro/Air with Intel processor or Apple M1 chip; compatible w/ Windows, macOS and Chrome OS.
6-PORT USB HUB: 4x USB-A (1x 10Gbps), 2x USB-C (1x 10Gbps), incl. 2x BC 1.2 fast charge always-on front ports; USB-C Gen 1 & USB-A laptops will only support downstream port speeds up to USB 5Gbps.
DEPLOYMENT READY: Docking station features a K-slot, 1m combo host cable, mounting holes, & MAC address changer for IT management; Gigabit Ethernet & headset ports; Windows, MacOS, Chrome OS.
HDMI & DisplayPort for Triple Monitor Outputs
This USB-C Gen 2 docking station with DP 1.4 and HDMI 2.0 support, is a perfect choice for dual or triple monitor setup, supporting up to triple 4K 60Hz display output, with any combination of three DisplayPort or HDMI video interfaces, on USB-C Gen 2 (with DP 1.4 support) laptops, MacBooks and Windows-based Thunderbolt 3 laptops. Older USB-A laptops will only support dual monitor setup. -
Power & Charge with 85W Power Delivery
Power and charge USB-C/Thunderbolt 3 workstation laptops & ultrabooks with 85 watt PD Higher power delivery, MORE than other USB-C 10G Triple monitor docks. Charge smartphones and other devices with two downstream front-facing charging ports with BC 1.2 for USB-A and USB-C devices. Fast-charge ports support always-on charging so devices will charge whether or not a host laptop is connected. -
Plenty of Downstream USB Ports
This USB-C Gen 2 docking station features 6 downstream USB ports in total to connect USB peripherals. • 1x USB-C 3.2 Gen 2 (10 Gbps) • 1x USB-A 3.2 Gen 2 (10 Gbps) • 1x USB-C 3.2 Gen 1 (5 Gbps) • 3x USB-A 3.2 Gen 1 (5 Gbps) Also included, is a gigabit Ethernet port with PXE Boot and WoL support, as well as 4-position TRRS stereo audio headset/mic port. -
Additional Security Features
This USB-C/USB-A docking station comes with plenty of security features such as a screw-lock host port which includes a USB-IF Certified 1m 2-in-1 USB-C/USB-A screw-lock cable, and a K-slot for a Kensington style laptop lock. For added security, or flexibility where desk space is limited, this dock can be mounted to the wall, monitor, or underneath the desk with StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA). These mounting brackets (not included) are specifically designed for our docks and hubs to give you the customized setup you need. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : To setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : To improve network security. •Text | USB Event Monitoring Utility : To track and log connected USB devices •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
- StarTech.com USB-C & USB-A Dock, Hybrid Universal Triple Monitor Laptop Docking Station w/ DisplayPort & HDMI 4K 60Hz, 85W Power Delivery, 6x USB Hub, Ethernet, Audio, USB 3.1 Gen 2 10Gbps - Multi-Monitor Dock (DK31C3HDPDUE) - docking station - USB-C - 3 x HDMI, 3 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C
- Video Interfaces
- 3 x HDMI, 3 x DP
- 8.4 cm x 23.3 cm x 3.7 cm
- 365 g
- Grey, black
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100/240 V 85 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 8.4 cm
- 23.3 cm
- 3.7 cm
- 365 g
- Enclosure Colour
- Grey, black
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- 3 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.1 Gen 2 - 24 pin USB-C , 1 x USB-C 3.1 Gen 1 (data only) - 10 pin USB-C , 3 x display / video - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 3 x display / video - 20 pin DisplayPort , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 1 x USB-C 3.0 - 24 pin USB-C , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A
- Cables Included
- 1 x USB-C/USB-A screw-lock cable - external - 1 m
- Security lock slot (cable lock sold separately), USB pass-through connector, UASP transfer protocol, Preboot Execution Environment (PXE) support, full duplex support, up to 3 monitors support, HDR support
- Security Slot Type
- Kensington security slot
- FCC, RoHS, USB Battery Charging Specification Rev. 1.2, DisplayPort 1.2, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
- Power Device
- Power adapter
- Voltage Required
- AC 100/240 V
- Power Provided
- 85 Watt
- OS Required
- Windows 8 / 8.1 / 10 / 11, Apple MacOS X 10.6 - 10.12, Apple macOS 10.14 - 11.0, Apple macOS 12.0, Apple macOS 13.0, Ubuntu 18.04, Ubuntu 20.04, Google Chrome OS
- Limited warranty - 3 years
- Shipping Width
- 9 cm
- Shipping Depth
- 25 cm
- Shipping Height
- 17.1 cm
- Shipping Weight
- 1.7 kg
- 0 °C
- 50 °C
StarTech.com 6 ft HDMI to DVI-D Cable - M/M | In Stock | £7.91 |
StarTech.com HDMI to DVI-D Video Cable Adapter - M/F | In Stock | £8.54 |
StarTech.com DisplayPort to DVI Video Adapter Converter | In Stock | £9.00 |
StarTech.com 10 ft DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k | In Stock | £13.35 |
StarTech.com HDMI to VGA Adapter Converter for Desktop PC / Laptop / Ultrabook - 1920x1080 | In Stock | £22.25 |
StarTech.com 10m Active DisplayPort Cable - DP to DP M/M | In Stock | £29.63 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.11 |
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £7.86 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.60 |
StarTech.com Docking Station Mount - Wall Mount / Under-Desk Mounting Pla | In Stock | £9.27 |
StarTech.com Docking Station Mount - For StarTech.com Docks / Hubs - VESA | In Stock | £14.31 |
StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.52 |
StarTech.com VESA Mounting Bracket | In Stock | £7.61 |
