This USB-C Triple 4K Monitor Docking Station enables wide workstation flexibility, featuring compatibility with USB-C, or Thunderbolt 3/Thunderbolt 4 laptops, and supporting multiple combinations of Ultra HD 4K DisplayPort and HDMI monitors.
Enhance Productivity with Triple-4K Video
This triple-4K docking station uses a combination of its integrated DisplayLink graphics controller and your computer's DP Alt Mode enabled USB-C port to provide three independent 4K displays. Connect any combination of HDMI and/or DisplayPort monitors to Video Ports 1 and 2 (DisplayLink ); at resolutions up to 4K at 60Hz. Connect an HDMI monitor to Video Port 3 (DP Alt-Mode), at resolutions up to 4K at 30Hz. This high-resolution video performance is ideal for detailed graphics applications, enhancing your productivity?by expanding the display capabilities of your laptop. -
Full-Featured Docking Station
Connect the docking station to your computer's USB 3.2 Gen 2 (10Gbps) Type-C port to provide a wide range of port connectivity, options and features. The docking station features: • 2x USB-A and 1x USB-C (USB 3.2 Gen 1 5Gbps) ports for USB peripheral devices. • 1x USB-A and 1x USB-C (USB 3.2 Gen 2 10Gbps) port that supports BC 1.2 with 7.5W (1.5A) for charging tablets and smartphones. • 1x Gigabit Ethernet port with WoL (Wake-on-LAN) for a wired Local Area Network (LAN) connection. • 1x 3.5mm 4-position TRRS Audio Jack for a 3.5mm headset. -
100W USB Power Delivery
The USB-C docking station supports 100W USB Power Delivery with the included power adapter. This allows you to charge the connected host device, as well as the devices connected to the BC 1.2 USB charging ports. For added protection to connected USB devices, the BC 1.2 enabled USB charging ports feature Overcurrent Protection (OCP). OCP prevents USB peripherals from drawing more power than is safely allocated for the port. -
Easy Deployment
Connect the dock to your host computer, using the included 3.3ft (1m) USB-C cable. The docking station supports all major operating systems, including Windows, macOS, ChromeOS, and Ubuntu. This dock was designed for seamless integration with any compatible USB-C equipped device within your organization, including Lenovo X1/Thinkpad P Series, Dell Latitudes/Precision/XPS 15, HP Envy, Surface Laptop 3, and M1 Pro/Max/M2 MacBooks. The dock features a side-facing K-Slot for added security in shared workspaces (e.g., BYOD hoteling/hot-desking). -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Advanced Windows Layout Utility : Setup and save custom windows layouts. •Text | Mac Address Pass-Through Utility : Improve network security. •Text | USB Event Monitoring Utility : Track and log connected USB devices. •Text | Wi-Fi Auto Switch Utility : Enable users to quickly access faster network speeds via wired LAN.
- StarTech.com USB-C Triple Monitor Docking Station - HDMI/DP Triple 4k USB-C Dock - 5x USB Hub - GbE - 100W PD - Universal Multi Monitor Docking Station - Thunderbolt 3/4 Compatible (116U-USBC-DOCK) - docking station - USB-C 3.2 Gen 2 - 2 x HDMI, 2 x DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB-C 3.2 Gen 2
- Video Interfaces
- 2 x HDMI, 2 x DP
- 19 cm x 8.5 cm x 3 cm
- 339 g
- Space grey
- Localisation
- United Kingdom
- Networking
- Gigabit Ethernet
- Power
- Power adapter AC 100-240 V 100 Watt Power Provided
- 3-year warranty
- Product Type
- Docking station
- 19 cm
- 8.5 cm
- 3 cm
- 339 g
- Enclosure Colour
- Space grey
- Localisation
- United Kingdom
Video
- Max Resolution Details
- 4096 x 2160 - 60 Hz (Triple Display (2 x HDMI / DisplayPort))
- Data Link Protocol
- USB 3.2 Gen 2, USB 3.2 Gen 1, IEEE 802.3ab
- 3 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - 20 pin DisplayPort , 1 x USB 3.2 Gen 2 with Fast Charging - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 with Fast Charging - 24 pin USB-C , 1 x USB-C 3.2 Gen 1 - 24 pin USB-C , 2 x USB 3.2 Gen 1 - 9 pin USB Type A , 1 x headphone/microphone combo jack - mini-phone 3.5 mm 4-pole , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) - 24 pin USB-C
- Cables Included
- 1 x USB-C cable - detachable - 1 m
- Security lock slot (cable lock sold separately), wake on LAN, power key with LED, DisplayPort Alt Mode, DisplayLink DL-6950 chipset, 100W power delivery, overcurrent protection
- Security Slot Type
- Kensington security slot
- DisplayPort 1.4, USB Battery Charging Specification Rev. 1.2, USB Power Delivery 2.0, WEEE, FCC, RoHS
- Power Device
- Power adapter
- Voltage Required
- AC 100-240 V
- Power Provided
- 100 Watt
- OS Required
- Android, Apple macOS Big Sur 11.0, Apple macOS Monterey 12.0, Apple MacOS X 10.11 - 10.12, Apple MacOS X 10.14 - 10.15, Google Chrome OS, Linux 3.5.x - 5.15.x LTS versions only, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS Ventura 13.0
- Limited warranty - 3 years
- Shipping Width
- 25 cm
- Shipping Depth
- 20.5 cm
- Shipping Height
- 5 cm
- Shipping Weight
- 1.2 kg
- 0 °C
- 70 °C
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £12.23 |
StarTech.com 2m 6ft Premium HDMI 2.0 Cable | In Stock | £15.37 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £19.66 |
