StarTech.com USB-C Triple-Monitor Adapter
Quicklinx: HSV7WS00 Mfr#: 154B-USBC-MULTIPORT
£106.60 ex VAT
£127.92 inc VAT
The StarTech.com USB-C Triple-Monitor Multiport Adapter is a comprehensive docking solution designed to meet the needs of professionals seeking to expand their workstation's connectivity and display capabilities. With support for triple display setups at 4K resolution and 60 Hz, this adapter ensures that users can enjoy high-quality visuals across multiple monitors. It features a wide range of ports including HDMI, DisplayPort, USB 3.2 Gen 1, and USB 2.0, providing the flexibility to connect a variety of devices. Additionally, the adapter supports USB-C Power Delivery of up to 100 W, allowing users to charge their devices directly through the adapter for a streamlined workspace. The inclusion of Ethernet, Fast Ethernet, and Gigabit Ethernet support enhances network performance, making it suitable for both remote and in-office work environments. Encased in a durable aluminum/plastic enclosure, and with an integrated 30 cm USB-C cable, this adapter is not only robust but also portable, making it an ideal choice for professionals on the move.
  • Versatile connectivity
    The USB-C Triple-Monitor Multiport Adapter offers a wide range of connections, including HDMI, DisplayPort, USB 3.2 Gen 1, and USB 2.0, ensuring compatibility with a variety of devices and monitors. This versatility makes it an ideal solution for professionals seeking to enhance their workstation setup.
  • High-resolution support
    Designed to support triple display setups with resolutions up to 4K at 60 Hz, this adapter ensures crisp, clear visuals on all connected displays. Whether for detailed data analysis, graphic design, or video editing, users can expect exceptional image quality.
  • Integrated power delivery
    With USB-C Power Delivery of up to 100 W, users can charge their devices directly through the adapter, eliminating the need for multiple power sources. This feature not only simplifies the workspace but also ensures that devices remain charged and ready to use.
  • Enhanced network performance
    Featuring support for Ethernet, Fast Ethernet, and Gigabit Ethernet, the adapter facilitates seamless network connections. It's equipped with wake on LAN and full duplex support, optimizing network performance for both remote and in-office work environments.
  • Durable and portable design
    The adapter's aluminum/plastic enclosure not only provides durability but also offers a lightweight, portable solution for professionals on the go. Its integrated 30 cm USB-C cable ensures a tidy setup without the need for additional cables.
StarTech.com USB-C Triple-Monitor Multiport Adapter, HDMI/DP/Card Reader - docking station - USB-C 3.2 Gen 1 / Thunderbolt 3 / Thunderbolt 4 - HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
Video Interfaces
HDMI, 2 x DP
5.6 cm x 13 cm x 1.6 cm
106 g
Space grey
Gigabit Ethernet
15 Watt
3-year warranty
Docking station
5.6 cm
13 cm
1.6 cm
106 g
Enclosure Colour
Space grey
Video
Max Resolution Details
3840 x 2160, 4K - 60 Hz (Triple Display) , 3840 x 2160, 4K - 60 Hz (Dual Display)
IEEE 802.3, IEEE 802.3ab, IEEE 802.3u
Expansion Slots
1 (total) / 1 (free) x SD / MMC Memory Card , 1 (total) / 1 (free) x microSD
1 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - 20 pin DisplayPort , 1 x USB 3.2 Gen 1 - 9 pin USB Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x audio - mini-phone 3.5 mm
1 x USB-C 3.2 Gen 1 cable - integrated - 30 cm
Triple display support, Preboot Execution Environment (PXE) support, full duplex support, bus powered, wake on LAN, DisplayPort Alt Mode, 100W power delivery (pass-through), aluminium/plastic enclosure
DisplayPort 1.4, RoHS, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0
Power Consumption (Max)
15 Watt
Google Chrome OS 78.x, Windows 8.1 / 10 / 11
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
120 g
70 °C
HSV7 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
HSV7 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
