StarTech.com USB-C Triple-Monitor Adapter
Quicklinx: HJFCWS00 Mfr#: 117B-USBC-MULTIPORT
Device Type: Laptop
Type: Docking Stations
Device Screen Size: [N/A]
Colour: Grey
Hurry, only 2 left in stock!
£85.93 ex VAT
£103.11 inc VAT
This USB Type-C Multiport Adapter utilizes DP 1.4 Alt Mode and MST technologies from a host computer to support up to three DisplayPort and/or HDMI displays. The USB-C docking station provides 2x HDMI outputs, 2x DisplayPort outputs, a 3-port USB 3.2 Gen 2 Type-A (10Gbps) Hub, and a Gigabit Ethernet port, all through one connection to a laptop's USB-C or Thunderbolt 3/4 port. In addition, it offers advanced charging through a dedicated USB-C Power Delivery (PD) 3.0 pass-through port via an integrated 2 ft. (60 cm) USB-C host cable. The USB-C Multiport Adapter features driverless installation for hassle-free setup.
  • High-Performance Triple Video via MST
    The USB-C Multiport Adapter enhances video connectivity with support for up to three external monitors with resolutions up to 2x 4K (3840 x 2160p) at 60Hz and 1x 4K (3840 x 2160p) at 30Hz (Intel 11th Gen or later with DSC required for maximum performance). The Multiport Adapter features two HDMI 2.0b ports and two DisplayPort 1.4 ports, providing the ability to choose a combination of video outputs types. The Multiport Adapter utilizes the integrated or discrete GPU capabilities of the connected laptop to enable high performance graphics with minimal CPU usage. Video performance, such as resolution and refresh rate across all three monitors, is dependent upon the host computer's graphics processing unit (GPU). A source device with support for DisplayPort 1.4 with DSC and MST is required to achieve maximum performance. Please review the specifications the host computer and the monitors to determine expected video performance.
  • Connect USB Peripherals
    The USB-C to USB 3.2 Gen 2 (10Gbps) hub features three USB-A ports for connecting USB HID devices and/or peripherals (e.g., storage devices).
  • Extra Long Cable & Durable Build
    The mini docking station features a built-in 2 ft. (60 cm) USB-C host cable with a high-quality TPE jacket and strain relief, for enhanced durability and longevity. The Multiport Adapter housing features a built-in EMI shield to protect the main board and integrated chips from electromagnetic interference, preventing signal interference between electronic devices and ensuring reliable performance.
  • 100W Power Delivery
    Connect a USB-C power adapter to the pass-though port in order to charge the host laptop. PD 3.0 features Fast Role Swap (FRS) which prevents USB data disruption when switching power sources (e.g., USB-C power adapter to bus power).
  • Reliable Network Connectivity
    The Gigabit Ethernet port ensures reliable wired network access. Support for Wake on Lan (WoL) allows you to boot the host computer from a remote location.
StarTech.com USB-C Triple-Monitor Multiport Adapter, Dual 4K 60Hz + 4k 30Hz HDMI & DisplayPort, 3-Port USB 10Gbps Hub, 100W Power Delivery Pass-Through, GbE, 2ft Cable, Mini Dock - Travel Laptop Docking Station (117B-USBC-MULTIPORT) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 / Thunderbolt 4 - 2 x HDMI, 2 x DP - 1GbE
Docking station
Docking Interface
Video Interfaces
2 x HDMI, 2 x DP
5.6 cm x 12.2 cm x 1.8 cm
113 g
Grey
Gigabit Ethernet
15 Watt
3-year warranty
Docking station
5.6 cm
12.2 cm
1.8 cm
113 g
Enclosure Colour
Grey
Video
Max Resolution Details
3840 x 2160, 4K (Triple Display) , 3840 x 2160, 4K - 60 Hz (Dual Display)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
2 x display / video - HDMI - 19 pin HDMI Type A , 2 x display / video - DisplayPort - 20 pin DisplayPort , 3 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C
1 x USB-C 3.2 Gen 2 cable - integrated - 60 cm
Wake on LAN, Preboot Execution Environment (PXE) support, full duplex support, bus powered, DisplayPort Alt Mode, plastic housing, triple display support, 100W power delivery (pass-through), up to 10Gbps data transfer, EMI shielding
FCC, RoHS, WEEE, RCM, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0, DisplayPort 1.2 (Alt Mode)
Power Consumption (Max)
15 Watt
Windows 8.1 / 10 / 11, Google Chrome OS 78.x
Limited warranty - 3 years
Shipping Width
12.4 cm
Shipping Depth
24.1 cm
Shipping Height
3.2 cm
Shipping Weight
210 g
70 °C
HJFC StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
HJFC StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.85
HJFC StarTech.com USB-C Triple-Monitor Adapter In Stock £85.35
Device Type: Laptop
Colour: Grey
