StarTech.com USB-C Triple DP MST HUB 4K
Quicklinx: J1K8WS00 Mfr#: MST14CD123DP
£54.44 ex VAT
£65.32 inc VAT
This USB-C to DisplayPort MST Hub enables a connection to three DisplayPort monitors, using a DisplayPort Alternate Mode (DP Alt Mode) capable USB-C enabled host device.
  • IT Pro Performance
    This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands.
  • Multi-tasking Made Easy
    This USB-C to DisplayPort video splitter allows you to configure your displays in extended or duplicated mode. Connecting three independent 4K 60Hz displays creates high-performance workstations. This empowers increased multi-tasking across your organization, resulting in increased productivity.
  • 4K at 60Hz and HDR
    Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into three independent signals, one for each DisplayPort enabled display. Support for High Dynamic Range (HDR) offers increased contrast, brightness, colors, and greater luminosity.
  • Hassle-Free Setup
    Windows devices that support DP Alt Mode over USB-C feature native support for MST. This USB-C to DisplayPort hub is compatible with Thunderbolt 3/4, and USB4 enabled Windows devices. Plug-and-play installation, with no drivers or software required. The 12in (30cm) attached cable provides options for flexible installation configurations, reducing the amount of strain on ports and connectors. Additionally, this triple-monitor splitter is bus-powered, meaning no external power is required. This product is backed for 3-years, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com USB-C to Triple DisplayPort 1.4 MST Hub, 4K 60Hz, 1ft (30cm) Cable, USB Type-C Multi Monitor Adapter for Laptop, DP 1.4 Multi-Stream Transport Hub, DisplayPort Splitter - MST Triple Monitor Adapter (MST14CD123DP) - docking station - USB-C / Displayport - 3 x DP
Docking station
Docking Interface
USB-C / Displayport
Video Interfaces
3 x DP
10.5 cm x 4.3 cm x 1.4 cm
54 g
Grey
3-year warranty
Docking station
10.5 cm
4.3 cm
1.4 cm
54 g
Enclosure Colour
Grey
3 x display / video - DisplayPort input - 20 pin DisplayPort
Compatible Slots
Audio / video
1 x USB-C cable - external
MST (multi-stream transport), High Bit Rate 3 (DSC), High Bit Rate 3 (HBR3), 32.4 Gbps HDMI bandwidth, HDR support, USB-C Alt Mode
RoHS, WEEE
Microsoft Windows 10 / 11
Limited warranty - 3 years
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
110 g
J1K8 StarTech.com 3ft DisplayPort 1.4 8K 60Hz In Stock £14.26
J1K8 StarTech.com 6ft DisplayPort 1.4 8K 60Hz In Stock £15.57
J1K8 StarTech.com 10ft DisplayPort 1.4 8K 60Hz In Stock £29.89
J1K8 StarTech.com 13ft DisplayPort 1.4 8K 60Hz In Stock £33.32
J1K8 StarTech.com 16ft DisplayPort 1.4 8K 60Hz In Stock £35.92
