This USB-C to VGA and HDMI adapter offers a portable solution for connecting your USB Type-C laptop to a VGA or HDMI display. The multiport video adapter also works as a splitter, enabling you to simultaneously output an identical video signal to two separate monitors (1 x HDMI and 1 x VGA).
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. With VGA, and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
The HDMI output on this USB-C video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1200.
The USB-C video adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
Two-in-One Video Connectivity with Travel in Mind
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. With VGA, and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport adapter. The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag. -
Ultra HD 4K 30Hz Resolution
The HDMI output on this USB-C video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1200. -
Stylish Connectivity for Your MacBook, MacBook Pro, or Any Laptop
The USB-C video adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices. CDP2HDVGA is backed by a StarTech.com 3-year warranty and free lifetime technical support.
- StarTech.com USB-C to VGA and HDMI Adapter - 2-in-1 - 4K 30Hz - Space Grey - Windows & Mac Compatible (CDP2HDVGA) - external video adapter - IT6222 - space grey
- External video adapter
- Bus Type
- USB-C
- Graphics Engine
- IT6222 - up to
- Max Resolution
- 3840 x 2160
- Max Resolution Details
- HDMI: 3840 x 2160 / VGA: 1920 x 1200
- Interfaces Details
- VGA (female connector) , HDMI output (female connector)
- 6.2 cm x 3.6 cm x 1.6 cm
- Enclosure Colour
- Space grey
- 3-year warranty
- Bus Type
- USB-C
- Graphics Engine
- IT6222
- Max Resolution
- 3840 x 2160 at 30 Hz
- HD/4k Ready, 5.1 surround sound
- Cables Included
- USB-C cable - 15.24 cm
- WEEE, RoHS, FCC
- 6.2 cm
- 3.6 cm
- 1.6 cm
- 90 g
- Enclosure Colour
- Space grey
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 5 - 90%
StarTech.com USB-C to VGA, DVI or HDMI | In Stock | £38.60 |
StarTech.com DisplayPort to HDMI VGA Adapter - 4K 60Hz - Multiport Video | In Stock | £22.14 |
StarTech.com USB C Multiport Video Adapter - VGA or Mini DisplayPort - HD | In Stock | £14.94 |
StarTech.com USB C Multiport Video Adapter - HDMI or DisplayPort - HDR 4K60 - Display Adapter | In Stock | £31.81 |
