StarTech.com USB C to VGA and HDMI Adapter - Aluminum - USB-C Multiport Adapter - 6" Built-In Cable
Quicklinx: F2HKWS00 Mfr#: CDP2HDVGA
Hurry, only 3 left in stock!
£30.85 ex VAT
£37.02 inc VAT
This USB-C to VGA and HDMI adapter offers a portable solution for connecting your USB Type-C laptop to a VGA or HDMI display. The multiport video adapter also works as a splitter, enabling you to simultaneously output an identical video signal to two separate monitors (1 x HDMI and 1 x VGA).
Avoid the hassle of carrying different adapters, with a 2-in-1 USB-C monitor adapter. With VGA, and HDMI outputs, you can conveniently connect your laptop to any HDMI or VGA-equipped display, using this multiport adapter.
The adapter features a durable aluminum enclosure and can withstand being carried in your travel bag.
The HDMI output on this USB-C video adapter supports UHD resolutions up to 4K 30Hz, while the VGA output supports HD resolutions up to 1920 x 1200.
The USB-C video adapter has a Space Gray housing and built-in USB-C cable designed to match your Space Gray MacBook or MacBook Pro. The adapter is compatible with USB-C DP Alt Mode devices.
StarTech.com USB-C to VGA and HDMI Adapter - 2-in-1 - 4K 30Hz - Space Grey - Windows & Mac Compatible (CDP2HDVGA) - external video adapter - IT6222 - space grey
External video adapter
Bus Type
USB-C
Graphics Engine
IT6222
Max Resolution
3840 x 2160
Max Resolution Details
HDMI: 3840 x 2160 / VGA: 1920 x 1200
VGA (female connector) , HDMI output (female connector)
6.2 cm x 3.6 cm x 1.6 cm
Enclosure Colour
Space grey
3-year warranty
Bus Type
USB-C
Graphics Engine
IT6222
Max Resolution
3840 x 2160 at 30 Hz
HD/4k Ready, 5.1 surround sound
USB-C cable - 15.24 cm
FCC, RoHS, WEEE
6.2 cm
3.6 cm
1.6 cm
90 g
Enclosure Colour
Space grey
Limited warranty - 3 years
45 °C
5 - 90%
F2HK StarTech.com USB C Multiport Video Adapter 4K/1080p - USB Type C to HDMI, VGA, DVI or Mini DisplayPort Monitor Adapter - Silver Aluminum - video interface converter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £53.64
F2HK StarTech.com USB-C to VGA, DVI or HDMI In Stock £45.35
F2HK StarTech.com USB C Multiport Video Adapter - Rose Gold In Stock £55.05
F2HK StarTech.com USB C Multiport Video Adapter - Space Gray In Stock £55.05
F2HK StarTech.com 4-in-1 USB-C to MDP, VGA, DVI or HDMI Adapter In Stock £60.53
Price Range Ex VAT: 0 - 50
