StarTech.com USB C to VGA Adapter 1080p
Quicklinx: GPJMWS00 Mfr#: CDP2VGAEC
11 In Stock
£21.85 ex VAT
£26.22 inc VAT
Extended Cable 1920x1200p Thunderbolt 3 Compatible. This USB-C to VGA adapter enables you to output high-definition VGA video from the USB Type-C port on your laptop, tablet, smartphone or other USB C device.
Extended Cable Length
This USB C adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands.
HD Picture Quality
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a VGA monitor, projector or other display. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-def resolution.
Ultimate Portability
This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag while commuting between your home, office or traveling for business.
The CDP2DVGAEC is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Notes:
Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter.
  • Extended cable length
    This USB-C adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands.
  • HD picture quality
    The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a VGA monitor, projector or other display. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-definition resolution.
  • Ultimate portability
StarTech.com USB C to VGA Adapter, 1080p USB Type-C to VGA Adapter Dongle, USB-C (DP Alt Mode) to VGA Monitor/Display Video Converter, Thunderbolt 3 Compatible, 12" Long Attached Cable - USB C to VGA Converter (CDP2VGAEC) - adapter - VGA / USB - 30 cm
Cable
Adapter - VGA / USB
Max Output Resolution
1920 x 1200 - 60 Hz
Length
30 cm
Connectors
24 pin USB-C - male
Connectors (Second End)
HD-15 (VGA) - female
Thunderbolt 3
1200p support
3-year warranty
P/N: MXT101MM10, MXT101MM15, MXT101MMH100, MXT101MMHD10, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ1, MXT101MMHQ20, MXT101MMHQ3, MXT101MMHQ30, MXT101MMHQ35, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXT101MMHQ65, MXT101MMHQ70, MXT101MMHQFF, MXT101MMHU10, MXT101MMHU15, MXT101MMHU6, TB4CDOCK
Cable Type
Adapter 1200p support
Interface Supported
VGA / USB
Thunderbolt 3
Length
30 cm
HBR2 audio support, USB powered, DisplayPort Alternate Mode support
Adapters & Converters
1920 x 1200
Refresh Rate
60 Hz
Connectors
24 pin USB-C - male
15 pin HD D-Sub (HD-15) - female
3.5 cm
30.5 cm
1.5 cm
32 g
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Height
1 cm
Shipping Weight
34 g
Limited warranty - 3 years
P/N: MXT101MM, MXT101MM10, MXT101MM15, MXT101MMH100, MXT101MMHD10, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ, MXT101MMHQ1, MXT101MMHQ10, MXT101MMHQ100, MXT101MMHQ20, MXT101MMHQ25, MXT101MMHQ3, MXT101MMHQ30, MXT101MMHQ35, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ50, MXT101MMHQ55, MXT101MMHQ60, MXT101MMHQ65, MXT101MMHQ70, MXT101MMHQ75, MXT101MMHQFF, MXT101MMHU10, MXT101MMHU15, MXT101MMHU6, MXT101MMLP10, MXT101MMLP15, MXT101MMLP6, TB4CDOCK
GPJM StarTech.com USB C to DP Adapter - 8K/4K In Stock £15.05
GPJM StarTech.com USB C to mDP Adapter 12" Cable In Stock £15.59
