Extended Cable 1920x1200p Thunderbolt 3 Compatible. This USB-C to VGA adapter enables you to output high-definition VGA video from the USB Type-C port on your laptop, tablet, smartphone or other USB C device.
Extended Cable Length
This USB C adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands.
HD Picture Quality
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a VGA monitor, projector or other display. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-def resolution.
Ultimate Portability
This USB Type-C video adapter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag while commuting between your home, office or traveling for business.
The CDP2DVGAEC is backed by a 3-year StarTech.com warranty and free lifetime technical support.
Notes:
Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter.
Extended cable length
This USB-C adapter is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands. -
HD picture quality
The adapter supports video resolutions up to 1920x1200 or 1080p. You'll be surprised at the picture quality the adapter provides, even when connected to a VGA monitor, projector or other display. The adapter harnesses the video capabilities that are built into your USB Type-C connection, to deliver every detail in stunning high-definition resolution. -
Ultimate portability
- StarTech.com USB C to VGA Adapter, 1080p USB Type-C to VGA Adapter Dongle, USB-C (DP Alt Mode) to VGA Monitor/Display Video Converter, Thunderbolt 3 Compatible, 12" Long Attached Cable - USB C to VGA Converter (CDP2VGAEC) - adapter - VGA / USB - 30 cm
- Cable
- Adapter - VGA / USB
- Max Output Resolution
- 1920 x 1200 - 60 Hz
- Length
- 30 cm
- Black
- Connectors
- 24 pin USB-C - male
- Connectors (Second End)
- HD-15 (VGA) - female
- Thunderbolt 3
- 1200p support
- 3-year warranty
- Designed For
- P/N: MXT101MM10, MXT101MM15, MXT101MMH100, MXT101MMHD10, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ1, MXT101MMHQ20, MXT101MMHQ3, MXT101MMHQ30, MXT101MMHQ35, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ55, MXT101MMHQ60, MXT101MMHQ65, MXT101MMHQ70, MXT101MMHQFF, MXT101MMHU10, MXT101MMHU15, MXT101MMHU6, TB4CDOCK
- Cable Type
- Adapter 1200p support
- Interface Supported
- VGA / USB
- Thunderbolt 3
- Length
- 30 cm
- HBR2 audio support, USB powered, DisplayPort Alternate Mode support
- Black
Adapters & Converters
- 1920 x 1200
- Refresh Rate
- 60 Hz
- Connectors
- 15 pin HD D-Sub (HD-15) - female
- 3.5 cm
- 30.5 cm
- 1.5 cm
- 32 g
- Shipping Width
- 12.5 cm
- Shipping Depth
- 22.5 cm
- Shipping Height
- 1 cm
- Shipping Weight
- 34 g
- Limited warranty - 3 years
- Designed For
- P/N: MXT101MM, MXT101MM10, MXT101MM15, MXT101MMH100, MXT101MMHD10, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ, MXT101MMHQ1, MXT101MMHQ10, MXT101MMHQ100, MXT101MMHQ20, MXT101MMHQ25, MXT101MMHQ3, MXT101MMHQ30, MXT101MMHQ35, MXT101MMHQ40, MXT101MMHQ45, MXT101MMHQ50, MXT101MMHQ55, MXT101MMHQ60, MXT101MMHQ65, MXT101MMHQ70, MXT101MMHQ75, MXT101MMHQFF, MXT101MMHU10, MXT101MMHU15, MXT101MMHU6, MXT101MMLP10, MXT101MMLP15, MXT101MMLP6, TB4CDOCK
StarTech.com USB C to DP Adapter - 8K/4K | In Stock | £13.33 |
StarTech.com USB C to mDP Adapter 12" Cable | In Stock | £14.97 |
