StarTech.com USB-C to VGA, DVI or HDMI
Quicklinx: CKQHWS00 Mfr#: CDPVGDVHDB
Keep this compact converter with your laptop while you're traveling, to connect to virtually any monitor, television or projector. This 3-in-1 travel adapter offers a portable solution for connecting your USB-C computer to a VGA, DVI, or HDMI display.
The travel adapter is compatible with your DP alt mode computer. DP alt mode means your computer can pass a DisplayPort video signal through the USB-C port.
This travel adapter comes with a built-in black USB-C cable and works well with your Dell XPS, MacBook and any device that supports USB-C DP alt mode.
Instead of carrying three separate video adapters in your laptop bag, this 3-in-1 adapter gives you all the video outputs you'll need. With VGA, DVI and HDMI outputs, this adapter lets you connect from your laptop's USB Type-C port to almost any boardroom or classroom display, without the inconvenience of carrying a separate adapter for each display type.
With support for multiple video outputs and a small-footprint design, this adapter is the ideal plug-and-play solution for travel or BYOD (Bring Your Own Device) applications around the office.
The adapter features a built-in cable fastener. Simply tuck the cable into place along the side of the adapter for quick and secure storage while you're traveling to ensure the adapter is neatly stored in your travel bag.
The HDMI output on this travel adapter supports Ultra HD 4K resolutions, providing four times the picture quality of high-definition 1080p. The HDMI output is also backward compatible with lower resolutions, such as 1080p and 720p, so the adapter is also perfect for your legacy video equipment. The VGA and DVI outputs also support high-definition maximum resolutions of up to 1920 x 1200, so you can still enjoy excellent video quality.
The travel adapter is compatible with USB Type-C Intel Thunderbolt 3 devices that are capable of outputting a DisplayPort signal.
StarTech.com USB C Multiport Adapter - UHD 4K - USB C to VGA / DVI / HDMI - USB C Adapter - USB-C VGA Multiport Adapter (CDPVGDVHDB) - adapter - HDMI / DVI / VGA / USB - 11 cm
Cable
Adapter - HDMI / DVI / VGA / USB
Max Output Resolution
3840 x 2160 - 30 Hz
Length
11 cm
Black, silver
Connectors
24 pin USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , HD-15 (VGA) - female (output) , DVI-I - female (output)
Displayport 1.2/Thunderbolt 3
Active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
3-year warranty
Cable Type
Adapter active converter, 4K30Hz (3840 x 2160) support (HDMI), 1920 x 1200 (WUXGA) support 60Hz (DVI and VGA)
Interface Supported
Length
11 cm
DisplayPort Alternate Mode support, 7.1 channel Surround Sound
Black, silver
Adapters & Converters
3840 x 2160
Refresh Rate
30 Hz
Apple macOS Sierra 10.12.6 or later
Connectors
19 pin HDMI Type A - female (output) , 15 pin HD D-Sub (HD-15) - female (output) , 24+5 pin combined DVI - female (output)
FCC, RoHS
6 cm
1.8 cm
67 g
Shipping Width
14.4 cm
Shipping Depth
17.4 cm
Shipping Height
3.2 cm
Shipping Weight
165 g
Limited warranty - 3 years
