StarTech.com USB-C to VGA - Power Delivery
Quicklinx: CTW4WS00 Mfr#: CDP2VGAUCPW
Connect your USB Type-C laptop to a VGA display, while charging your laptop with a USB-C charge cable. The USB-C to VGA adapter lets you connect a USB-C laptop, such as your Macbook or MacBook Pro, to a VGA display. The video adapter features USB Power Delivery, which enables you to power your laptop while you're outputting video to a VGA display.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel . It's also compatible with Thunderbolt 3 ports.
With its all-white design and support for USB Power Delivery, this USB-C video adapter is the perfect accessory for your USB-C equipped MacBook. The adapter is compact and lightweight, so it fits easily into your MacBook bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
While the adapter looks great next to your MacBook or HP ENVY, it also works with any USB-C computer that supports DisplayPort ALT mode, such as your Windows laptop.
Unlike some video adapters that take up your laptop's USB-C charge port while you're outputting video and prevent you from charging your computer, this video adapter features an additional USB-C port dedicated to USB Power Delivery. This means you can charge your laptop, even while outputting video, by simply connecting the laptop's power adapter to the additional port. It's the perfect solution for laptops that only have a single USB-C port.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect, saving you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or share information.
With support for video resolutions up to 1920x1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your USB-C connection to deliver every detail in stunning high-definition.
  • The perfect travel companion for your MacBook with USB-C
  • Charges your laptop
  • Promotes portability
  • Connects easily
  • Maintains crystal-clear picture quality
    With support for video resolutions up to 1920 x 1200 or 1080p, you'll be surprised at the picture quality the adapter provides, even when connected to a legacy VGA monitor, projector or television. The adapter harnesses the video capabilities built into your USB-C connection to deliver every detail in stunning high-definition.
StarTech.com USB C to VGA Adapter with Power Delivery, 1080p USB Type-C to VGA Monitor Video Converter with Charging, 60W PD Pass-Through, Thunderbolt 3 Compatible Projector Adapter, White - Digital to Analog (CDP2VGAUCPW) - external video adapter - white
External video adapter
Bus Type
USB-C
Max Resolution
1920 x 1200
Interfaces Details
VGA
3.3 cm 1.5 cm
Length
15 cm
Enclosure Colour
White
3-year warranty
Bus Type
USB-C
Max Resolution
1920 x 1200
Interfaces Details
VGA
USB powered
FCC, RoHS, WEEE, RCM
3.3 cm
1.5 cm
Length
15 cm
24 g
Enclosure Colour
White
Limited warranty - 3 years
0 - 90%
CTW4 StarTech.com USB-C to VGA Adapter In Stock £22.16
CTW4 StarTech.com USB-C to HDMI Adapter In Stock £15.94
CTW4 StarTech.com USB-C to HDMI Adapter In Stock £15.52
CTW4 StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CTW4 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
CTW4 StarTech.com USB-C to 4K HDMI Adapter w/ PD In Stock £20.98
CTW4 StarTech.com USB-C to DisplayPort Adapter In Stock £22.59
