Compact and convenient design
The right-angled orientation of the USB-C male connector allows for unobstructed utilization of neighboring ports, perfect for tight setups. -
High-speed data transfer
With support for data rates up to 5 Gbps, this adapter ensures rapid file transfers between devices. -
Durable metal housing
Constructed with a metal housing, this adapter resists wear and tear while adding a sleek and professional look to your tech accessories. -
Broad compatibility
Compatible with a variety of USB standards, making it versatile for different devices and applications. -
No power requirement
As a passive adapter, it operates without needing an external power source, enhancing portability and ease of use.
