StarTech.com USB-C to USB-A Adapter, 5Gbps
Quicklinx: J1L1WS00 Mfr#: USB31CAADGCPRA
£5.87 ex VAT
£7.04 inc VAT
  • Compact and convenient design
    The right-angled orientation of the USB-C male connector allows for unobstructed utilization of neighboring ports, perfect for tight setups.
  • High-speed data transfer
    With support for data rates up to 5 Gbps, this adapter ensures rapid file transfers between devices.
  • Durable metal housing
    Constructed with a metal housing, this adapter resists wear and tear while adding a sleek and professional look to your tech accessories.
  • Broad compatibility
    Compatible with a variety of USB standards, making it versatile for different devices and applications.
  • No power requirement
    As a passive adapter, it operates without needing an external power source, enhancing portability and ease of use.
