Add a serial port with this USB C to serial with COM port retention. This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into an RS232 DB9 serial port with COM port retention. This gives you a cost-saving and convenient way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
A time-saving and convenient USB/serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be re-assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
The USB-C serial cable also supports advanced features like remote wake-up and power management control.
Versatile connectivity
This cable features a 9-pin D-Sub connector on one end, allowing for easy connection to a wide range of serial devices, including printers and modems. -
Modern compatibility
The male USB-C connector provides a direct link to newer laptops and devices, facilitating a smooth integration of older technology into contemporary computing environments. -
Reliable performance
With the Prolific PL2303RA chipset, this adapter ensures consistent and effective data transmission, making it suitable for high-demand applications. -
Safety compliance
Meeting various compliance standards such as FCC, RoHS, WEEE, and RCM ensures that this adapter cable is safe for both users and the environment.
 - StarTech.com USB C to Serial Adapter Cable with COM Port Retention, 16" (40cm) USB Type C to RS232 (DB9) Serial COM Port Converter Cable, For PLCs, Scanners, Printers, Windows/macOS/Linux - Up to 921.6 Kbps Baud (ICUSB232PROC) - USB / serial cable - DB-9 to 24 pin USB-C - 40 cm
 - Chipset Prolific PL2303RA
- Length
 - 40 cm
- Connector
 - 9 pin D-Sub (DB-9) - male
- Connector (Second End)
 - 24 pin USB-C - male
 - USB / USB 2.0
 - Black
 - 2-year warranty
- Length
 - 40 cm
 - Black
 - 10 g
- Connector
 - USB / USB 2.0, FCC, RoHS, WEEE, RCM
 - 2-year warranty
                        StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention | In Stock | £21.54 |
                        StarTech.com DB9 to DB25 Serial Cable Adapter - F/M | In Stock | £5.40 |
                        StarTech.com UCB C to Serial Adapter | In Stock | £16.60 |
                        StarTech.com USB C to RS232 Cable | In Stock | £21.47 |
