Brand
StarTech.com USB C to RS232 Cable
Quicklinx: D389WS00 Mfr#: ICUSB232PROC
15 in stock
£24.11 ex VAT
£28.93 inc VAT
Add a serial port with this USB C to serial with COM port retention. This USB-C to serial adapter lets you connect your USB-C devices to your legacy serial equipment. It converts a USB-C port on your laptop or computer into an RS232 DB9 serial port with COM port retention. This gives you a cost-saving and convenient way to connect to serial devices such as point-of-sale terminals, serial modems, industrial equipment, and a wide variety of other RS232 peripherals.
The RS232 adapter cable is compatible with Windows, macOS and Linux operating systems, which makes it easy to integrate into mixed environments.
A time-saving and convenient USB/serial solution, the adapter retains assigned serial COM port values in nonvolatile memory, allowing the same values to automatically be re-assigned to the adapter serial port if disconnected and reconnected, or disconnected from one USB port and installed in another.
The USB-C serial cable also supports advanced features like remote wake-up and power management control.
StarTech.com USB C to Serial Adapter Cable with COM Port Retention, 16" (40cm) USB Type C to RS232 (DB9) Serial COM Port Converter Cable, For PLCs, Scanners, Printers, Windows/macOS/Linux - Up to 921.6 Kbps Baud (ICUSB232PROC) - USB / serial cable - DB-9 to USB-C - 40 cm
USB / serial cable
Chipset Prolific PL2303RA
Length
40 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
24 pin USB-C - male
USB / USB 2.0
USB / serial cable
Length
40 cm
10 g
Connector
24 pin USB-C - male
USB / USB 2.0, FCC, RoHS, WEEE, RCM
D389 StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £19.31
D389 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £5.19
D389 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.35
D389 StarTech.com UCB C to Serial Adapter In Stock £20.61
D389 StarTech.com USB C to RS232 Cable In Stock £24.11
Stock Status: In stock
