StarTech.com USB-C to Mini DisplayPort
Quicklinx: D7VJWS00 Mfr#: CDP2MDP
Hurry, only 1 left in stock!
£14.77 ex VAT
£17.72 inc VAT
Express delivery Delivered on Tuesday
USB-C™ to Mini DisplayPort adapter lets you output mDP video and audio from the USB Type-C™ port on your laptop or other device. The adapter works with USB-C devices that pass a DisplayPort video signal (DP Alt Mode), such as your MacBook Pro, Chromebook™ or other USB-C laptop.
This versatile adapter enables you to connect a Mini DisplayPort monitor to your USB-C computer using a Mini DisplayPort cable, or re-purpose your existing mDP equipped workspace to work with your new USB-C computer.
  • IT Pro Performance
    This adapter features a unique video signal booster which amplifies the signal and ensures reliable performance, even with lower quality cables. The amplifier also increases the max. supported DP cable length compared to other brands.
  • Enjoy High-Definition Resolution up to 4K at 60Hz
    Harness the video capabilities that are built into your computer's USB-C connection, using the adapter to deliver the astonishing quality of UHD to your 4K 60Hz display. You can achieve an output resolution of up to 3840 x 2160p at 60Hz,?perfect for high-resolution tasks such as viewing 4K video. The USB-C video adapter is backward compatible with 1080p monitors or displays, which makes it a great accessory for workspace applications.
  • Hassle-Free Connection for Your USB Type-C Laptop
    This adapter lets you use the versatile USB Type-C port on your portable device. USB-C is a reversible connector, enabling you to plug it into your device in any direction. The Thunderbolt 3 compatible adapter provides a hassle-free connection to your Windows or Mac based Thunderbolt 3 computer.
  • Lightweight Design for Easy Portability
    The compact USB-C to mDP adapter is lightweight and fits perfectly in your laptop?bag. Its portable design is ideal for BYOD (Bring Your Own Device) applications at the office or on the road.? The CDP2MDP is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes: •Text | Your USB-C device must support DisplayPort over USB-C (DP Alt Mode) to work with this adapter •Text | This adapter outputs a single-mode Mini DisplayPort signal and will not work with additional video adapters such as Mini DisplayPort to HDMI, Mini DisplayPort to VGA or Mini DisplayPort to DVI adapters
StarTech.com USB-C to Mini DisplayPort Adapter - 4K 60Hz - White - USB 3.1 Type-C to Mini DP Adapter (CDP2MDP) - DisplayPort adapter - 24 pin USB-C to Mini DisplayPort - 18 cm
DisplayPort adapter
Passive adapter, 4K60Hz (3840 x 2160) support, DisplayPort Alternate Mode support, 7.1 audio channel support
Length
18 cm
Connector
24 pin USB-C - male (input)
Connector (Second End)
Mini DisplayPort - female (output)
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2
White
3-year warranty
DisplayPort adapter
Length
18 cm
White
2.7 cm
1.6 cm
23 g
Connector
USB 3.1 / Thunderbolt 3 / DisplayPort 1.2, FCC, RoHS
Shipping Width
12.5 cm
Shipping Depth
22.5 cm
Shipping Weight
31 g
3-year warranty
D7VJ StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.28
D7VJ StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.35
D7VJ StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £12.14
D7VJ StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.65
D7VJ StarTech.com USB-C to VGA Adapter In Stock £22.79
D7VJ StarTech.com USB-C to HDMI Adapter In Stock £19.31
D7VJ StarTech.com USB-C to DisplayPort Adapter In Stock £22.55
D7VJ StarTech.com USB-C to DP with USB PD In Stock £16.26
D7VJ StarTech.com 1.8m 6 ft USB C to mDP Cable In Stock £16.59
D7VJ StarTech.com Mini DisplayPort Cable - 4K 60Hz - Black - 3 ft / 1m In Stock £20.05
