StarTech.com USB-C to Micro-USB Adapter M/F
Quicklinx: C9X1WS00 Mfr#: USB2CUBADP
13 In Stock
£9.70 ex VAT
£11.64 inc VAT
Connect your USB Type-C mobile device to a USB-A host, using a standard Micro-USB Cable. This USB-C to Micro-USB adapter lets you charge and sync USB Type-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using a Micro-USB cable.
Simply insert the adapter's USB-C connector into your mobile device. Then, plug your Micro-USB cable into the adapter's Micro-USB port and connect the cable to the USB-A port on your computer or USB-A wall charger.
The compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables that you need to carry around with you in order to charge all of your mobile devices.
StarTech.com USB C to USB Micro B - USB Type C to USB M / F - USB 2.0 - USB C Connector - USB-C to USB Micro B Adapter (USB2CUBADP) - USB-C adapter - 24 pin USB-C to Micro-USB Type B
USB-C adapter
Connector
24 pin USB-C - male
Connector (Second End)
5 pin Micro-USB Type B - female
USB / USB 2.0
USB-C adapter
Plated Connector
Nickel
5.1 g
Connector
24 pin USB-C - male
USB / USB 2.0, RoHS
C9X1 StarTech.com USB 3.1 USB-C to USB-A Adapter In Stock £10.84
C9X1 StarTech.com 1m USB 3.1 USB-C to USB-A Cbl In Stock £10.98
C9X1 StarTech.com 1m USB 3.1 C to Micro-B Cable In Stock £11.16
C9X1 StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M In Stock £14.29
C9X1 StarTech.com 1m USB 2.0 USB-C to USB-A Cable In Stock £9.37
C9X1 StarTech.com 1m USB 2.0 USB-C to USB-B Cable In Stock £17.06
C9X1 StarTech.com 6ft USB-C to A Cable - USB 2.0 In Stock £11.44
