Connect your USB Type-C mobile device to a USB-A host, using a standard Micro-USB Cable. This USB-C to Micro-USB adapter lets you charge and sync USB Type-C mobile devices, such as the Nokia N1 tablet and Nexus 6P and 5X phones, using a Micro-USB cable.
Simply insert the adapter's USB-C connector into your mobile device. Then, plug your Micro-USB cable into the adapter's Micro-USB port and connect the cable to the USB-A port on your computer or USB-A wall charger.
The compact adapter is portable enough for carrying as a tablet or laptop accessory and it reduces the number of cables that you need to carry around with you in order to charge all of your mobile devices.
Reliable connectivity
This USB C to USB Micro B adapter ensures stable connections between USB-C devices and Micro-USB peripherals, facilitating seamless data transfer and charging. -
Durable design
Constructed with nickel-plated connectors, this adapter is built to withstand frequent use while maintaining optimal signal quality.
- StarTech USB C to USB Micro B - USB Type C to USB M / F - USB 2.0 - USB C Connector - USB-C to USB Micro B Adapter (USB2CUBADP) - USB-C adapter - USB-C to Micro-USB Type B
- USB-C adapter
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- 5 pin Micro-USB Type B - female
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB-C adapter
- Plated Connector
- Nickel
- Black
- 5.1 g
- Connector
- USB / USB 2.0, RoHS
StarTech.com USB 3.1 USB-C to USB-A Adapter | In Stock | £8.87 |
StarTech.com 1m USB 3.1 USB-C to USB-A Cbl | In Stock | £7.48 |
StarTech.com 1m USB 3.1 C to Micro-B Cable | In Stock | £10.24 |
StarTech.com 1m 3ft USB 3.1 USB-C Cable M/M | In Stock | £12.99 |
StarTech.com 1m USB 2.0 USB-C to USB-A Cable | In Stock | £8.64 |
StarTech.com 1m USB 2.0 USB-C to USB-B Cable | In Stock | £9.97 |
StarTech.com 6ft USB-C to A Cable - USB 2.0 | In Stock | £11.27 |
