StarTech.com USB C to mDP Adapter 12" Cable
Quicklinx: GKNCWS00 Mfr#: CDP2MDPEC
Length: 30.6cm
£14.97 ex VAT
£17.96 inc VAT
This USB-C to Mini DisplayPort adapter enables you to output mDP video and audio from the USB Type-C port on your laptop, tablet, smartphone or other USB C device.
  • Extended Cable Length
    This USB C adapter dongle is equipped with an extra-long 12" (30cm) attached cable, providing an extended reach to reduce port and connector strain on 2-in-1 devices or laptops on risers stands.
  • Ultra HD 4K Resolution
    The adapter lets you harness the video capabilities that are built into your computer's USB Type-C connection, to deliver the astonishing quality of UHD to your 4K 60Hz display. This makes it easier for you to multitask while working on the most resource-demanding applications imaginable. Plus, the USB-C to Mini DP adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
  • Ultimate Portability
    This USB C to mDP video converter is highly portable with a small footprint and lightweight design that's easy to tuck into your laptop bag while commuting between your home, office or traveling for business. The CDP2MDPEC is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes: • Your USB-C device must support DisplayPort over USB-C (DP alt mode) to work with this adapter
StarTech USB C to Mini DisplayPort Adapter, 4K 60Hz USB-C to mDP Adapter Dongle, USB Type-C to Mini DP Monitor/Display, Video Converter, Works w/ Thunderbolt 3, 12" Long Attached Cable - DP Alt Mode, mDP 1.2 (CDP2MDPEC) - video adapter - USB-C to Mini DisplayPort - 30.6 cm
Video adapter
4K60Hz (3840 x 2160) support, plastic housing, HBR2 support, DisplayPort Alternate Mode support
Cable Length
30.6 cm
Connector
24 pin USB-C - male
Connector (Second End)
Mini DisplayPort - female
Displayport 1.2/Thunderbolt 3
Grey
3-year warranty
Video adapter
Cable Length
30.6 cm
Grey
2.7 cm
1.6 cm
28 g
Connector
24 pin USB-C - male
Displayport 1.2/Thunderbolt 3, FCC, RoHS, HDCP 2.2, HDCP 1.4
Shipping Width
20 cm
Shipping Depth
22 cm
Shipping Height
1.8 cm
Shipping Weight
31 g
3-year warranty
GKNC StarTech.com 6 ft Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £9.24
GKNC StarTech.com 1m (3 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £3.73
GKNC StarTech.com 2m (6 ft) White Mini DisplayPort to DisplayPort 1.2 Adapter Cable M/M - DisplayPort 4k In Stock £14.18
GKNC StarTech.com 4m Mini DisplayPort to DisplayPort Adapter Cable - M/M In Stock £19.68
GKNC StarTech.com USB C to DP Adapter - 8K/4K In Stock £13.33
GKNC StarTech.com USB C to VGA Adapter 1080p In Stock £8.18
Length: 30.6cm
