StarTech.com USB C to Lightning Cable Black
Quicklinx: GPJWWS00 Mfr#: RUSB2CLT50CMBC
Length: 50cm
11 In Stock
£11.64 ex VAT
£13.96 inc VAT
This coiled Lightning to USB C cable can withstand the daily demands of charging and syncing your mobile devices. It contracts to 1ft (30cm) making it compact and convenient to store.
  • Built for Daily Use
    The durable Lightning charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable.
  • Flexible Strain Relief
    The Lightning to USB-C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 5,000+ bend cycles at a 180° angle.
  • Superior Connection
    The durable cable supports all USB 2.0 specifications providing a dependable connection for all your Lightning devices. It is also Apple MFi certified which is guaranteed for fast and reliable charge and sync from USB-C charging ports. RUSB2CLT50CMBC is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com 50cm/20in USB C to Lightning Cable, MFi Certified, Coiled iPhone Charger Cable, Black, Durable and Flexible TPE Jacket Aramid Fiber, Heavy Duty Coil Charging Cable - Rugged USB Lightning Cable - Lightning cable - 50 cm
Cable
Lightning cable
American Wire Gauge (AWG)
22/32
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - male
USB / USB 2.0
Coiled
Cable Type
Lightning cable coiled
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
USB / USB 2.0
Length
50 cm
Plated Connector
Nickel
Recommended Use
Mobile phone, tablet, portable player
Sync and charge, aramid reinforced core, strain relief
Connector
24 pin USB-C - male
Apple Lightning - male
MFI, RoHS, WEEE
Shipping Width
14.5 cm
Shipping Depth
7.5 cm
Shipping Height
1.7 cm
Shipping Weight
30 g
Length: 50cm
