This coiled Lightning to USB C cable can withstand the daily demands of charging and syncing your mobile devices. It contracts to 1ft (30cm) making it compact and convenient to store.
Built for Daily Use
The durable Lightning charging cable has aramid fiber reinforcement that shelters it from the stress of frequent bends. This also lets the cable flex without over-stretching or damaging the core of the cable. -
Flexible Strain Relief
The Lightning to USB-C cable is constructed to prevent the connector from separating from the jacket. The extra-long strain relief molding is tested to withstand over 5,000+ bend cycles at a 180° angle. -
Superior Connection
The durable cable supports all USB 2.0 specifications providing a dependable connection for all your Lightning devices. It is also Apple MFi certified which is guaranteed for fast and reliable charge and sync from USB-C charging ports. RUSB2CLT50CMBC is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 50cm/20in USB C to Lightning Cable, MFi Certified, Coiled iPhone Charger Cable, Black, Durable and Flexible TPE Jacket Aramid Fiber, Heavy Duty Coil Charging Cable - Rugged USB Lightning Cable - Lightning cable - 50 cm
- Cable
- Lightning cable
- American Wire Gauge (AWG)
- 22/32
- Length
- 50 cm
- Black
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - male
- USB / USB 2.0
- Coiled
- 2-year warranty
- Cable Type
- Lightning cable coiled
- 22/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- USB / USB 2.0
- Length
- 50 cm
- Plated Connector
- Nickel
- Recommended Use
- Mobile phone, tablet, portable player
- Sync and charge, aramid reinforced core, strain relief
- Black
- Connector
- Apple Lightning - male
- MFI, RoHS, WEEE
- Shipping Width
- 14.5 cm
- Shipping Depth
- 7.5 cm
- Shipping Height
- 1.7 cm
- Shipping Weight
- 30 g
- Limited warranty - 2 years
StarTech.com USB C to Lightning Cable Black
