StarTech.com USB-C to Lightning Cable 1m
Quicklinx: H240WS00 Mfr#: RUSB2CLTMM1MR
Length: 1m
Hurry, only 1 left in stock!
£14.30 ex VAT
£17.16 inc VAT
Establish a right angle connection to a Lightning-enabled device (e.g., iPhone, iPad, iPad Mini, and some iPods) and to a USB Type-C power source, using this 3ft (1m) Durable USB-C to Lightning cable.
  • Built for Daily Use
    The durable Lightning charging cable features aramid fiber reinforcement that enhances tensile strength, abrasion resistance, and resistance to cable stress. This reinforced cable is able to flex without over-stretching. In addition, the connectors feature metal shells covered in fully-molded TPE for improved connector longevity. The USB Type-C to right-angled Lightning cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been assessed to withstand over 5,000+ bend cycles at a 180° angle.
  • Apple Certified
    The durable USB-C to right-angled Lightning cable supports USB 2.0 (480Mbps) specifications. It is Apple MFi certified which guarantees up to 3A fast charging and reliable data sync from USB-C charging ports. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
StarTech.com 3ft (1m) Durable USB-C to Lightning Cable - Right-Angled Heavy Duty Aramid Fiber USB Type-C to Lightning Charging/Sync Cord - Apple MFi Certified - Rugged iPhone Lightning Cable - Lightning cable - 1 m
Cable
Lightning cable
American Wire Gauge (AWG)
22/32
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
Lightning - male
USB / USB 2.0
Aramid reinforced core, rugged design, sync and charge, EMI protection, strain relief moldings
Cable Type
Lightning cable
22/32
Jacket Material
Thermoplastic elastomer (TPE)
Shielding Material
USB / USB 2.0
Length
1 m
Plated Connector
Nickel, gold
Recommended Use
iPhone, iPad, iPod
Connector
24 pin USB-C - male
Apple Lightning - male
MFI, RoHS, WEEE
23 g
Shipping Width
12.8 cm
Shipping Depth
22 cm
Shipping Height
3 cm
Shipping Weight
25.8 g
Length: 1m
