Establish a right angle connection to a Lightning-enabled device (e.g., iPhone, iPad, iPad Mini, and some iPods) and to a USB Type-C power source, using this 3ft (1m) Durable USB-C to Lightning cable.
Built for Daily Use
The durable Lightning charging cable features aramid fiber reinforcement that enhances tensile strength, abrasion resistance, and resistance to cable stress. This reinforced cable is able to flex without over-stretching. In addition, the connectors feature metal shells covered in fully-molded TPE for improved connector longevity. The USB Type-C to right-angled Lightning cable has been designed to prevent cable/connector strain. The extra-long strain relief moldings have been assessed to withstand over 5,000+ bend cycles at a 180° angle. -
Apple Certified
The durable USB-C to right-angled Lightning cable supports USB 2.0 (480Mbps) specifications. It is Apple MFi certified which guarantees up to 3A fast charging and reliable data sync from USB-C charging ports. This product is backed for life, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com 3ft (1m) Durable USB-C to Lightning Cable - Right-Angled Heavy Duty Aramid Fiber USB Type-C to Lightning Charging/Sync Cord - Apple MFi Certified - Rugged iPhone Lightning Cable - Lightning cable - 1 m
- Cable
- Lightning cable
- American Wire Gauge (AWG)
- 22/32
- Length
- 1 m
- Black
- Connector
- 24 pin USB-C - male
- Connector (Second End)
- Lightning - male
- USB / USB 2.0
- Aramid reinforced core, rugged design, sync and charge, EMI protection, strain relief moldings
- 2-year warranty
- Cable Type
- Lightning cable
- 22/32
- Jacket Material
- Thermoplastic elastomer (TPE)
- Shielding Material
- Aluminum mylar foil with braid
- USB / USB 2.0
- Length
- 1 m
- Plated Connector
- Nickel, gold
- Recommended Use
- iPhone, iPad, iPod
- Black
- Connector
- Apple Lightning - male
- MFI, RoHS, WEEE
- 23 g
- Shipping Width
- 12.8 cm
- Shipping Depth
- 22 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 25.8 g
- Limited warranty - 2 years
