StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter
Quicklinx: F2K9WS00 Mfr#: CDP2HD4K60H
More than 50 In Stock
£19.04 ex VAT
£22.84 inc VAT
This USB-C to HDMI adapter lets you connect your USB Type-C laptop to an HDMI display. The adapter supports High Dynamic Range (HDR) and provides sharper images with enhanced video.
With brighter colors and greater contrast, the adapter is ideal for: Creating eye-catching visuals for photography, videography, cinematography; Displaying crisp digital signage walls; Delivering enriched presentations.
The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions.
With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
This lightweight 4K adapter is highly portable, with a small-footprint design. It's the perfect accessory for your USB-C laptop or MacBook, fitting easily into your carrying case.
To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try.
To achieve HDR, your USB-C port must support DisplayPort 1.4 and your display must support HDMI 2.0b. NVIDIA graphics adapters may not support 4:4:4 chroma subsampling and 5.1/7.1 audio output, when used with this adapter.
  • True 4K at 60Hz and HDR
    The USB-C video adapter is fully compatible with your HDMI 2.0b equipment, supporting resolutions up to 4K 60Hz (3840 X 2160) and bandwidths up to 18Gbps. The adapter offers 4:4:4 chroma subsampling, so every pixel gets its own unique color. It's also backward compatible with earlier versions of HDMI and DisplayPort at their supported maximum resolutions. With HDR support, you can enjoy lifelike images with increased contrast, brightness and colors and greater luminosity than standard digital imaging.
  • Ideal for Travel
  • Hassle-Free Setup
    To ensure easy operation and installation, this unique USB-C to HDMI adapter includes a reversible USB-C connector so you will always plug it into your laptop correctly on the first try. CDP2HD4K60H is backed by a 3-year StarTech.com warranty and free lifetime technical support. Notes:
StarTech.com USB 3.1 Type C to HDMI Adapter with HDR - 4K 60Hz - TB3 Compatible - Windows & Mac Compatible Black USB C to HDMI Monitor Converter (CDP2HD4K60H) - external video adapter - MegaChips MCDP2900 - black
External video adapter
Bus Type
USB-C
Graphics Engine
MegaChips MCDP2900 - up to
Max Resolution
4096 x 2160
Interfaces Details
HDMI (female connector)
2.86 cm 1.14 cm
Length
5.6 cm
Enclosure Colour
3-year warranty
P/N: ST121HD20FXA, TB4CDOCK
Bus Type
USB-C
Graphics Engine
MegaChips MCDP2900
Max Resolution
4096 x 2160 at 60 Hz
Interfaces Details
HDR Ready
USB-C cable - 10.41 cm
FCC, RoHS, DisplayPort 1.4
2.86 cm
1.14 cm
Length
5.6 cm
30 g
Enclosure Colour
Limited warranty - 3 years
5 °C
35 °C
25 - 60%
F2K9 StarTech.com USB-C to HDMI Adapter In Stock £16.61
F2K9 StarTech.com USB-C to HDMI Adapter In Stock £19.31
F2K9 StarTech.com USB C Multiport Video Adapter with HDMI, VGA, Mini DisplayPort or DVI, USB Type C Monitor Adapter to HDMI 1.4 or mDP 1.2 (4K), VGA or DVI (1080p), Silver Aluminum Adapter - 4-in-1 USB-C Converter (CDPVGDVHDMDP) - adapter - Mini DisplayPort / HDMI / DVI / VGA - 10.5 cm In Stock £57.25
F2K9 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
F2K9 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £15.83
F2K9 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.43
F2K9 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.33
F2K9 StarTech.com USB-C to VGA, DVI or HDMI In Stock £38.60
F2K9 StarTech.com 5m 15ft Premium 4K HDMI Cable In Stock £24.09
F2K9 StarTech.com 7m 23ft Premium 4K HDMI Cable In Stock £35.52
F2K9 StarTech.com 0.5m Premium 4K HDMI Cable In Stock £9.92
F2K9 StarTech.com 3ft (1m) USB C to HDMI Cable 4K 60Hz /HDR10 - USB-C to HDMI In Stock £17.27
F2K9 StarTech.com 6ft (2m) USB C to HDMI Cable 4K 60Hz / HDR10 - USB-C to HDMI In Stock £18.11
F2K9 StarTech.com 9.8ft (3m) USBC to HDMI Cable 4K USB-C HDMI Media Convertor In Stock £27.91
F2K9 StarTech.com 13ft (4m) USB C to HDMI Cable 4K HDMI USB-C to HDMI Monitor In Stock £24.84
F2K9 StarTech.com 16ft (5m) USB C to HDMI Cable 4K USB-C to HDMI Monitor Conve In Stock £26.84
