StarTech.com USB-C to HDMI Adapter
Quicklinx: BTM3WS00 Mfr#: CDP2HD
More than 50 in stock
£17.77 ex VAT
£21.32 inc VAT
Connect your MacBook, Chromebook or laptop with USB-C to an HDMI display or projector. This USB-C to HDMI adapter lets you output HDMI video and audio from a USB Type-C device such as a MacBook or Chromebook laptop. This adapter works with USB-C devices that pass a DisplayPort video signal. It's also compatible with Thunderbolt 3 ports.
This USB type-C video adapter is highly portable with a small footprint and lightweight design. The adapter is the perfect accessory for your MacBook or Chromebook, fitting easily into your laptop bag or carrying case, which is great for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always work, saving you the hassle and embarrassment of fiddling with your device when you're trying to deliver a presentation.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities built into your USB Type-C connection, to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets. Plus, the adapter is backward compatible with 1080p displays, which makes it a great accessory for home, office or other workspace applications.
Note: Your USB-C equipped device must support video to work with this adapter.
  • Clutter-free installation
    At 1 m (3 ft.) in length, this adapter cable delivers a direct connection that eliminates excess adapters and cabling, ensuring a tidy, professional installation.
  • Hassle-free connection with USB Type-C
    The adapter cable is easy to connect, through the versatility and convenience of the USB Type-C port on your device. USB-C is a reversible connector, so it doesn't matter which way you plug it in, the adapter will always connect. This saves you the frustration of trying to insert it correctly when you're docking your computer to your workstation or office hot desk.
  • Astonishing picture quality
    At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. This adapter cable lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. The adapter is backward compatible with 1080p displays, ensuring the adapter will also work for HD applications at your home or office.
StarTech.com USB-C to HDMI Video Adapter Converter - 4K 30Hz - Thunderbolt 3 Compatible - USB 3.1 Type-C to HDMI Monitor Travel Dongle Black (CDP2HD) - external video adapter - black
External video adapter
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
Enclosure Colour
3-year warranty
Bus Type
USB-C
Max Resolution
3840 x 2160
HDMI
USB powered
Video Input
USB powered
FCC, RoHS
Enclosure Colour
Limited warranty - 3 years
BTM3 StarTech.com USB-C to HDMI Adapter In Stock £17.77
BTM3 StarTech.com USB-C to HDMI Adapter - 4K 60Hz In Stock £20.79
BTM3 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £20.73
BTM3 StarTech.com 1m USB-C to HDMI Cable In Stock £22.13
BTM3 StarTech.com USB-C to HDMI - Power Delivery In Stock £25.54
BTM3 StarTech.com USB-C to HDMI Presentation In Stock £24.08
Price Range Ex VAT: 0 - 50
