StarTech.com USB-C to HDMI - Power Delivery
Quicklinx: CK39WS00 Mfr#: CDP2HDUCP
11 In Stock
£23.58 ex VAT
£28.29 inc VAT
Using a single USB Type-C port on your laptop, output HDMI video and charge the laptop. This USB-C to HDMI adapter lets you connect your laptop or MacBook with USB Type-C to an HDMI display. The video adapter features USB Power Delivery, which enables you to power your laptop while you're outputting video to an HDMI display.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel. It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that take up your laptop's USB-C charge port while you're outputting video and prevent you from charging your computer, this video adapter supports USB Power Delivery and features an additional USB-C port. This means you can charge your laptop, even while outputting video, by simply connecting the laptop's power adapter to the additional port. It's the perfect solution for laptops that only have a single USB-C port.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect, saving you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets.
Even if you're not running 4K, the adapter supports high-definition 1080p and lower resolutions, which gives you peace of mind in knowing that this adapter will comfortably work with any HDMI video display you come across.
  • High Resolution Support
    The adapter supports a maximum output resolution of 4096 x 2160, delivering crisp and clear visuals on compatible displays.
  • Efficient Power Delivery
    Equipped with USB Power Delivery technology, the adapter can transfer up to 60 W of power, keeping connected devices charged during use.
  • Audio Clarity
    Designed to support 7.1 channel Surround Sound, this adapter enhances audio experiences whether for gaming, movies, or music.
  • Versatile Compatibility
    Compatible with a variety of devices thanks to its support for DisplayPort Alternate Mode, making it ideal for various uses.
  • Easy Setup
    The Plug-and-Play design of the adapter allows for quick and uncomplicated connections between devices.
Startech USB C to HDMI 2.0 Adapter with Power Delivery, 4K 60Hz USB Type-C to HDMI Display/Monitor Video Converter, 60W PD Pass-Through Charging Port, Thunderbolt 3 Compatible, Black - USB-C Display Adapter (CDP2HDUCP) - adapter - HDMI / USB
Cable
Adapter - HDMI / USB
Max Output Resolution
4096 x 2160 - 60 Hz
Connectors
USB-C - male (input)
Connectors (Second End)
HDMI - female (output) , USB-C (power only) - female
Displayport 1.2/Thunderbolt 3
USB Power Delivery (60W), 4K60Hz (4096 x 2160) support
3-year warranty
Cable Type
Adapter USB Power Delivery (60W), 4K60Hz (4096 x 2160) support
Interface Supported
HDMI / USB
DisplayPort Alternate Mode support, 7.1 channel Surround Sound
Adapters & Converters
4096 x 2160
Refresh Rate
60 Hz
Apple MacOS, Linux, Microsoft Windows, Google Chrome OS, Apple iPadOS
Connectors
24 pin USB-C - male (input)
19 pin HDMI Type A - female (output) , 24 pin USB-C (power only) - female
FCC, RoHS, HDCP 2.2, HDCP 1.4, USB Power Delivery
3.3 cm
5 cm
1.3 cm
24 g
Shipping Width
14.6 cm
Shipping Depth
17.4 cm
Shipping Height
3.2 cm
Shipping Weight
106 g
Limited warranty - 3 years
CK39 StarTech.com USB-C to HDMI Adapter In Stock £15.52
CK39 StarTech.com 2m USB-C to DVI Cable In Stock £23.46
CK39 StarTech.com 2m USB-C to HDMI Cable In Stock £27.94
CK39 StarTech.com 1m 3ft Premium HDMI 2.0 Cable In Stock £11.32
CK39 StarTech.com 2m 6ft Premium HDMI 2.0 Cable In Stock £16.00
CK39 StarTech.com 3m 10ft Premium HDMI 2.0 Cable In Stock £20.46
CK39 StarTech.com USB-C to HDMI Adapter - 4K60Hz In Stock £16.30
CK39 StarTech.com 1m USB-C to HDMI Cable In Stock £25.27
CK39 StarTech.com USB-C to HDMI - Power Delivery In Stock £23.58
CK39 StarTech.com USB-C to HDMI Presentation In Stock £14.13
CK39 StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter In Stock £19.36
CK39 StarTech.com USB C to mDP Adapter 12" Cable In Stock £14.97
CK39 StarTech.com USB C to HDMI Adapter 4K 60Hz In Stock £12.49
