Using a single USB Type-C port on your laptop, output HDMI video and charge the laptop. This USB-C to HDMI adapter lets you connect your laptop or MacBook with USB Type-C to an HDMI display. The video adapter features USB Power Delivery, which enables you to power your laptop while you're outputting video to an HDMI display.
USB Type-C is a universal connectivity standard that combines all of your essential functions into one dynamic port. This adapter works with USB-C devices that pass a DisplayPort video signal, such as the MacBook and Chromebook Pixel. It's also compatible with Thunderbolt 3 ports.
Unlike some video adapters that take up your laptop's USB-C charge port while you're outputting video and prevent you from charging your computer, this video adapter supports USB Power Delivery and features an additional USB-C port. This means you can charge your laptop, even while outputting video, by simply connecting the laptop's power adapter to the additional port. It's the perfect solution for laptops that only have a single USB-C port.
This USB Type-C video adapter maximizes portability with a lightweight, small-footprint design. It's the perfect accessory to carry with your MacBook or Chromebook, fitting easily into your laptop bag or carrying case. Its ultra-portable design makes this adapter perfect for BYOD (Bring Your Own Device) applications at the office.
This adapter lets you utilize the versatile USB Type-C port on your portable device. USB Type-C is a reversible connector, so no matter how you plug it in, the adapter will always connect, saving you the hassle and embarrassment of struggling with your device when you're trying to deliver a presentation or sharing information.
At four times the resolution of high-definition 1080p, you'll be amazed at the picture quality of a 4K monitor or television. The adapter lets you harness the video capabilities that are built into your USB Type-C connection to deliver the astonishing quality of Ultra HD to your 4K display. 4K resolution gives you additional screen space to simplify your approach to detailed work such as editing video and viewing large spreadsheets.
Even if you're not running 4K, the adapter supports high-definition 1080p and lower resolutions, which gives you peace of mind in knowing that this adapter will comfortably work with any HDMI video display you come across.
- StarTech.com USB C to HDMI 2.0 Adapter with Power Delivery, 4K 60Hz USB Type-C to HDMI Display/Monitor Video Converter, 60W PD Pass-Through Charging Port, Thunderbolt 3 Compatible, Black - USB-C Display Adapter (CDP2HDUCP) - adapter - HDMI / USB
- Cable
- Adapter - HDMI / USB
- Max Output Resolution
- 4096 x 2160 - 60 Hz
- Black
- Connectors
- 24 pin USB-C - male (input)
- Connectors (Second End)
- HDMI - female (output) , USB-C (power only) - female
- Displayport 1.2/Thunderbolt 3
- USB Power Delivery (60W), 4K60Hz (4096 x 2160) support
- 3-year warranty
- Cable Type
- Adapter USB Power Delivery (60W), 4K60Hz (4096 x 2160) support
- Interface Supported
- HDMI / USB
- DisplayPort Alternate Mode support, 7.1 channel Surround Sound
- Black
Adapters & Converters
- 4096 x 2160
- Refresh Rate
- 60 Hz
- OS Required
- Apple MacOS, Linux, Microsoft Windows, Google Chrome OS, Apple iPadOS
- Connectors
- 19 pin HDMI Type A - female (output) , 24 pin USB-C (power only) - female
- FCC, RoHS, HDCP 2.2, HDCP 1.4, USB Power Delivery
- 3.3 cm
- 5 cm
- 1.3 cm
- 24 g
- Shipping Width
- 14.6 cm
- Shipping Depth
- 17.4 cm
- Shipping Height
- 3.2 cm
- Shipping Weight
- 106 g
- Limited warranty - 3 years
StarTech.com USB-C to VGA Adapter - White | In Stock | £21.61 |
StarTech.com USB-C to HDMI Adapter | In Stock | £18.71 |
StarTech.com 2m USB-C to DVI Cable | In Stock | £24.18 |
StarTech.com 2m USB-C to HDMI Cable | In Stock | £31.44 |
StarTech.com 1m 3ft Premium HDMI 2.0 Cable | In Stock | £10.94 |
StarTech.com 3m 10ft Premium HDMI 2.0 Cable | In Stock | £20.37 |
StarTech.com USB-C to VGA - Power Delivery | In Stock | £23.19 |
StarTech.com USB-C to HDMI Adapter - 4K60Hz | In Stock | £16.84 |
StarTech.com 1m USB-C to HDMI Cable | In Stock | £27.75 |
StarTech.com USB-C to HDMI - Power Delivery | In Stock | £25.52 |
StarTech.com USB-C to HDMI Presentation | In Stock | £16.68 |
StarTech.com USB-C to HDMI Adapter with HDR - 4K 60Hz - Black - USB Type C to HDMI Converter | In Stock | £19.81 |
StarTech.com Portable USB C to HDMI Adapter with Keychain | In Stock | £10.15 |
StarTech.com Portable USB C to Mini DisplayPort Adapter w/ Keychain | In Stock | £8.92 |
StarTech.com USB C to mDP Adapter 12" Cable | In Stock | £25.88 |
StarTech.com USB C to HDMI Adapter 4K 60Hz | In Stock | £12.41 |
