StarTech.com USB C to Gigabit Ethernet Network Adapter
Quicklinx: DHP2WS00 Mfr#: US1GC30DB
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: PC, Mac
Type: Network adapter
13 In Stock
£15.45 ex VAT
£18.54 inc VAT
Connect to a Gigabit Ethernet network through your computer's USB-C port. This USB-C to Gigabit Ethernet adapter lets you connect easily to a wired Ethernet network, with full Gigabit bandwidth support, through the USB-C or Thunderbolt 3 port on your laptop, tablet or desktop computer.
The USB Type-C to Gigabit Ethernet adapter adds a single RJ45 Ethernet port with Gigabit support, by harnessing the performance of USB 3.0, also known as USB 3.1 Gen 1 (5 Gbps). You can access very large files over the network at Gigabit speeds. Support for features such as jumbo frames, VLAN tagging and Wake-on-LAN (WOL), provides versatile Gigabit network performance for business or home office use.
Get up and running quickly. Simply plug the adapter into the USB-C port on your laptop and connect to your network. The network adapter chipset provides native driver support for the latest versions of Windows, macOS, Linux, and Chrome OS, providing easy setup.
Compact, lightweight and with a cableless design, this portable USB Gigabit network adapter is the ideal accessory for your MacBook Pro, Dell XPS or other USB-C enabled laptop or desktop computer. It's powered directly from the USB port, making it easy to connect when you're on the go.
  • Powerful Gigabit network connections
  • Native driver support makes installation easy
    Get up and running quickly. Simply plug the adapter into the USB-C port on your laptop and connect to your network. The network adapter chipset provides native driver support for the latest versions of Windows , macOS, Linux , and Chrome OS , providing easy setup.
  • Designed for portability
    Compact, lightweight and with a cableless design, this portable USB Gigabit network adapter is the ideal accessory for your MacBook Pro, Dell XPS or other USB-C enabled laptop or desktop computer. It's powered directly from the USB port, making it easy to connect when you're on the go. The US1GC30DB is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to Gigabit Ethernet Adapter, 1Gbps NIC USB 3.0/USB 3.1 Type C Network Adapter, 1GbE USB-C to RJ45/LAN Port, Thunderbolt 3 Compatible, Windows, MacBook Pro, Chromebook - USB C to Ethernet (US1GC30DB) - network adapter - USB-C - Gigabit Ethernet x 1
Network adapter
External
Interface (Bus) Type
USB-C
Ports
2.02 cm x 4.42 cm x 1.3 cm
9 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
5 Gbps
Jumbo frame size: 9000
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Data Transfer Rate
5 Gbps
Status Indicators
Power, active
WOL, USB powered, Thunderbolt 3 compatible, VLAN Tagging (not supported in MacOS)
1 x 1000Base-T - RJ-45 - female
FCC, RoHS, WEEE, RCM
2.02 cm
4.42 cm
1.3 cm
9 g
Shipping Weight
120 g
60 °C
5 - 90%
DHP2 StarTech.com USB-C to Ethernet Adapter In Stock £14.41
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: PC
Compatibility: Mac
