StarTech.com USB-C to Gigabit Adapter
Quicklinx: BLK6WS00 Mfr#: US1GC30W
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Form Factor: External
Compatibility: Mac, PC
Type: Network adapter
Hurry, only 1 left in stock!
£24.60 ex VAT
£29.52 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Add a Gigabit Ethernet port to your MacBook, Chromebook or laptop with USB Type-C. Now you can easily connect to a Gigabit network through the USB-C or Thunderbolt 3 port on your laptop or desktop computer. This Gigabit Ethernet (GbE) network adapter provides a reliable network connection without even having to install drivers. It's ready to go, with native driver support to ensure a quick setup.
The USB Type-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.1 Gen 1 (5 Gbps). You can access very large files over the network at Gigabit speeds.
Get up and running quickly. Simply plug the adapter into the USB-C port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
The USB Type-C connector is smaller and easier to use than previous USB connectors. It's a reversible plug so you can connect to your devices with either side facing up. You can insert the cable the right way every time - without frustration or the risk of port damage.
Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. It's powered directly from the USB port making it easy to connect when you're on the go. Plus, its lightweight design makes the adapter the perfect travel accessory for your Chromebook Pixel or MacBook.
The US1GC30W features a white design that looks great with your Apple Mac.
  • Powerful Gigabit network connections
    The USB Type-C network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.2 Gen 1 (5 Gbps). You can access very large files over the network at Gigabit speeds.
  • Native driver support makes installation easy
  • Trouble-free connections through USB-C
  • Compact and lightweight for perfect portability
    Compact and portable, this USB Gigabit network adapter is the ideal desktop network adapter or laptop accessory. It's powered directly from the USB port making it easy to connect when you're on the go. Plus, its lightweight design makes the adapter the perfect travel accessory for your Chromebook Pixel or MacBook. The US1GC30W features a white design that looks great with your Apple Mac and is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to Gigabit Ethernet Adapter - White - USB 3.1 to RJ45 LAN Network Adapter - USB Type C to Ethernet (US1GC30W) - network adapter - USB-C - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
USB-C
Ports
Gigabit Ethernet
2.5 cm 1.5 cm
Length
21 cm
30 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Realtek Semiconductor RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.1
White
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Linux Kernel 2.6.25 or later, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.7 - 10.15, Apple macOS 11.0, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Gigabit Ethernet
Wired
Cabling Type
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, IPv4 and IPv6 Large Send Offload and Checksum Offload (LSO/TCO), Jumbo Frames support, plastic housing, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
1 x 1000Base-T - RJ-45 - female
FCC, RoHS
White
2.5 cm
1.5 cm
Length
21 cm
30 g
70 °C
5 - 90%
BLK6 StarTech.com USB 3.0 to Gigabit Ethernet NIC Network Adapter In Stock £23.78
BLK6 StarTech.com USB-C to Gigabit Adapter In Stock £24.10
BLK6 StarTech.com USB-C to Gigabit Adapter In Stock £24.60
BLK6 StarTech.com USB-C to Gigabit Adapter In Stock £37.94
BLK6 StarTech.com USB-C to GbE Adapter - Silver In Stock £28.74
BLK6 StarTech.com 3 Port USB 3.0 Hub with USB-C and GbE 3 ports - Desktop In Stock £52.58
BLK6 StarTech.com USB-C to Dual GbE Adapter In Stock £57.13
BLK6 StarTech.com 3 Port USB 3.0 Hub GbE - USB-C - White In Stock £39.55
BLK6 StarTech.com 3PT USB 3.0 C Hub + GbE PD 2.0 In Stock £51.07
BLK6 StarTech.com USB-C Ethernet Adapter with Extra USB Port - USB 3.1 Type-C In Stock £36.60
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
