StarTech.com USB-C to GbE Adapter - PD
Quicklinx: CTW8WS00 Mfr#: US1GC30PD
Wired / Wireless: Wired
Protocol: Fast Ethernet, Gigabit Ethernet, Ethernet
Form Factor: External
Compatibility: PC, Unix, Mac
Type: Network adapter
£36.21 ex VAT
£43.45 inc VAT
Connect to a GbE network through your laptop's USB-C port, and charge while you work with Power Delivery. Now you can add a wired network connection to your USB-C enabled laptop, tablet or desktop computer. Ideal for mobile use, this USB-C to Ethernet adapter plugs into your USB-C or Thunderbolt 3 port to provide wired network access. Plus you can charge your laptop as you work. It makes a great companion for your MacBook, Chromebook Pixel, Dell XPS 12, or other device.
Extend the capability of your laptop's USB-C port, by gaining a wired internet connection virtually anywhere you go. The USB-C network adapter connects to your USB-C port to provide a reliable Gigabit Ethernet connection. It supports full Gigabit bandwidth, by harnessing the performance of USB 3.0 (5 Gbps), also known as USB 3.1 Gen 1, letting you quickly access large files over the network. You can connect to a network in locations where Wi-Fi is unavailable or unreliable, such as in classrooms, offices, and hotels.
The USB-C network adapter lets you power and charge your laptop as you work. The adapter supports Power Delivery 2.0, so instead of carrying multiple power adapters, you can use your laptop's USB-C power adapter to power both your laptop and network adapter. Note: just make sure your laptop's USB-C based power adapter supports USB Power Delivery 2.0.
Compact and portable, this USB-C Gigabit network adapter is the ideal desktop network adapter or laptop accessory. It's powered directly from the USB port making it easy to connect when you're on the go.
This Gigabit Ethernet (GbE) network adapter provides a reliable network connection without even having to install drivers. It's ready to go - the network adapter chipset provides native driver support to ensure a quick setup. Simply plug the adapter into the USB-C port on your laptop and connect to your network.
  • Access reliable Gigabit network connections
  • Power and charge as you work
  • Compact and lightweight for perfect portability
  • Native driver support makes installation easy
    This Gigabit Ethernet (GbE) network adapter provides a reliable network connection without even having to install drivers. It's ready to go - the network adapter chipset provides native driver support to ensure a quick setup. Simply plug the adapter into the USB-C port on your laptop and connect to your network. The US1GC30PD is backed by a StarTech.com 2-year warranty and free lifetime technical support.
StarTech.com USB C to Gigabit Ethernet Adapter/Converter w/ PD 2.0, 1Gbps USB 3.1 Type C to RJ45/LAN Network w/ Power Delivery Pass Through Charging, TB3 Compatible/ MacBook Pro Chromebook - USB Type-C to Ethernet (US1GC30PD) - network adapter - USB-C - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
USB-C
Ports
Gigabit Ethernet
3.9 cm x 6.25 cm x 1.65 cm
24 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
5 Gbps
Realtek Semiconductor RTL8153
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, USB 3.0
Google Chrome OS, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.11 - 10.15, Apple macOS 11.0, Microsoft Windows 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
5 Gbps
Status Indicators
Link/activity
Full duplex capability, WOL, auto-uplink (auto MDI/MDI-X), USB powered, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging (not supported in MacOS)
Processor / Memory
1 x 1000Base-T - RJ-45 - female , 1 x USB-C - 24 pin USB-C (power only) - female
FCC, RoHS, WEEE, RCM
3.9 cm
6.25 cm
1.65 cm
24 g
70 °C
5 - 90%
CTW8 StarTech.com USB-C to Gigabit Adapter In Stock £24.60
CTW8 StarTech.com USB-C GbE Adapter + 3-Port Hub In Stock £46.34
Protocol: Gigabit Ethernet
Protocol: Ethernet
Compatibility: PC
Compatibility: Unix
Compatibility: Mac
