StarTech.com USB C to Fiber Optic Converter
Quicklinx: DFR9WS00 Mfr#: US1GC30SFP
£212.52 ex VAT
£255.02 inc VAT
This USB-C to fiber-optic converter lets you utilize the USB 3.0 (Type-C) port on your laptop or tablet to provide a secure fiber network connection. Windows and Mac compatible, the network adapter provides a Gigabit Ethernet (1000 Mbps) optical network connection for portable laptops or tablets, or systems without expansion slots.
  • A flexible solution with an open SFP slot
    The open SFP slot enables you to use your preferred SFP transceiver module to meet your networking needs - use an SFP with your desired wavelength, distance, connection type to achieve an efficient network solution. (SFP sold separately.)
  • Secure fiber-to-the-desk connectivity
    This USB to fiber-optic converter provides reliable fiber connectivity while protecting your network from problems with electronic interference - a common issue with copper Ethernet networks. Fiber-to-the-desk connectivity (FTTD) maximizes network security, reducing the risk of data leaks for sensitive information, without compromising network speed and reliability.
  • Easy portability
    Compact and portable, this USB-C to fiber-optic converter is powered directly from the USB port.
  • Plug and play
    Get up and running quickly. The USB to fiber-optic converter supports certified drivers for Windows, Mac and Linux . Once the adapter is plugged into a USB-C port, you simply install the drivers and the adapter is ready to transmit over a fiber network.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: •Text | Mac Address Pass-Through Utility : To improve network security. •Text | Wi-Fi Auto Switch Utility : Enabling users to quickly access faster network speeds via wired LAN.
StarTech.com USB C to Fiber Optic Converter - Open SFP - 1000BASE-SX/LX - Windows / Mac / Linux - USB Ethernet Adapter - USB Network Adapter (US1GC30SFP) - network adapter - USB-C - 1000Base-LX/1000Base-SX x 1
Network adapter
External
Interface (Bus) Type
USB-C
Ports
5.5 cm x 26 cm x 2 cm
100 g
Cabling Type
Ethernet 1000Base-LX, Ethernet 1000Base-SX
1GbE
Data Transfer Rate
1 Gbps
Jumbo frame size: 9000
IEEE 802.3z, IEEE 802.1Q
Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux Kernel 3.5 or later, Apple MacOS X 10.9 - 10.14, Linux LTS versions only, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
Network adapter
External
USB-C
Ports
Wired
Cabling Type
Gigabit Ethernet
Data Transfer Rate
1 Gbps
Status Indicators
Power, link/activity
WOL, USB powered, plastic housing
1 x 1000Base-LX/SX - SFP (mini-GBIC) - female
Plug and Play, MSA
5.5 cm
26 cm
2 cm
100 g
60 °C
5 - 90%
DFR9 StarTech.com 3m Multimode 62.5/125 Duplex Fiber Patch Cable LC - SC In Stock £18.80
DFR9 StarTech.com Gigabit Ethernet Multi Mode Fiber Media Converter SC 550m - 1000 Mbps In Stock £147.80
DFR9 StarTech.com Fiber Media Converter - w/ SFP In Stock £69.61
DFR9 StarTech.com 1000Base-LX SFP - SM LC- 10 km In Stock £42.65
DFR9 StarTech.com 1000Base-SX SFP - MM LC- 550 m In Stock £25.26
DFR9 StarTech.com USB 3 Fiber Converter Open SFP In Stock £206.96
DFR9 StarTech.com USB 2.0 to Fiber Converter In Stock £146.90
DFR9 StarTech.com USB C to Fiber Optic Converter In Stock £212.52
Type: Fibre Converter
