Add a Gigabit network port to your computer, using a USB Type-C connection. The RJ45 port supports multiple speeds (10/100/1000 Mbps) and is fully compatible with Cat5 [and higher] cabling. This is an essential peripheral for new laptops that lack an Ethernet port. In addition, it can be utilized or whenever WiFi is unavailable or when wireless network speeds are inconsistent.
                Access Gigabit NetworksThe USB LAN adapter supports up to Gigabit speeds (1000 Mbps). Share or receive files over a network, access network storage/backup, and stream online content while reducing wait times and slowdowns.
                Plug and Play Device ConfigurationSimply connect the network adapter to your computer's USB Type-C port. Native driver support in Windows, macOS, and Linux facilitates plug-and-play compatibility. In addition, mobile platforms are also supported, including ChromeOS, Android, and iPadOS. This USB-C to RJ45 dongle features VLAN tagging, Auto-MDIX, 9K jumbo frames, wake-on-LAN, and full-duplex Ethernet making it the perfect companion for on-the-go users who require a wired network connection.
                Compact and Versatile DesignThe USB Gigabit network adapter is light and compact. It features a built-in 11.8 in (30 cm) cable that helps with additional reach and flexibility while reducing cable/connector strain. Additionally, USB bus power simplifies the setup and makes it a convenient accessory while on the move. US1GC30B2 is backed for 2-years by StarTech.com, including free lifetime 24/5 multi-lingual technical assistance.
- StarTech.com USB-C to Ethernet Adapter, 10/100/1000 Mbps, Gigabit Network Adapter w/ ASIX AX88179A Chip, 1ft/30cm Cable, USB Type C to RJ45 Ethernet Dongle, USB C to LAN Adapter, Windows/macOS/Linux/ChromeOS (US1GC30B2) - network adapter - USB-C - Gigabit Ethernet x 1
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB-C
- Ports
- 17.4 cm x 2.7 cm x 1.6 cm
- 23 g
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 5 Gbps
- Capacity
- Jumbo frame size: 9000
- Processor
- ASIX AX88179A
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3az, USB 3.2 Gen 1
- Grey
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Android, Google Chrome OS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Linux Kernel 2.6.14 or later, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux LTS versions only, Apple MacOS X 10.9 - 10.15, Microsoft Windows Server 2022, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0
- 2-year warranty
- Network adapter
- Form Factor
- External
- USB-C
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 5 Gbps
- Capacity
- WOL, auto-uplink (auto MDI/MDI-X), full duplex mode, Jumbo Frames support, Energy Efficient Ethernet, VLAN Tagging
Processor / Memory
- Processor
- ASIX AX88179A
- 1 x 1000Base-T - RJ-45 - female
- MTBF
- 262,800 hours
- FCC, RCM
- Grey
- OS Required
- 17.4 cm
- 2.7 cm
- 1.6 cm
- 23 g
- Shipping Width
- 17 cm
- Shipping Depth
- 14.2 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 90 g
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 85%
